SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
SOURCE: Hello, I have the Homedics
My initial thought was that the battery might be getting low, but for this model, the battery is supposed to last the lifetime of the product.
Regardless of whether this is an issue with the battery or the unit, the scale should be under the manufacturer's lifetime limited warranty.
You can contact the Homedics by phone at: 1-800-466-3342. You can also contact them via email from their online form:
http://www.homedics.com/home/contacts/
Hope this was helpful.
