Question about Rowenta Perfect Iron
Rowenta dw9150 leaking - Rowenta Perfect Iron
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
Leaky rowenta iron
Not a solution, but a word of caution. I have purchased several Rowentas, one more expensive than the previous one; all of them leaked. This time it went beyond a wet ironing board, there were sparks in the water tank near the temperature light. From the comments it seems the fix is GE.
Feb 15, 2012 | Rowenta Irons
My Steam Iron Rowenta dx1700 leaks on my clothes and turns itself off while I am ironong. I am ready to chuck it.
My brand new DX1700 iron leaks. Why is it leaking. I had a Rowenta Professional for 17 years and it never leaked. What do I need to do.
Jan 12, 2011 | Rowenta Perfect Iron
My rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
Oct 14, 2010 | Rowenta DG5030 Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
THIRD leaking Rowenta
Try buying a cheap one from wallmart or some similar store. They are not too dear so you can use them until they fail and then buy another cheap one.
Jul 27, 2009 | Rowenta Perfect Iron
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Rowenta Perfect Iron Logo
171 people viewed this question
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
