Not in English, but easy enough to follow:
Ricondizionamento ripristino di un pc in 10 minuti Fujitsu Siemens E300
SOURCE: cannot get into bios on fujitsu siemens scenic
what are you trying to do?
you cant access it or you dont know the password?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: I need sata driver for fujitsu siemens SCENIC P300
Here is link to fujitsu support for driver downloads. Hope it helpls.
http://ts.fujitsu.com/support/downloads.html
Good Luck
SOURCE: fujitsu siemens scenic p300 vga
Hi.
There are different P300 versions.
Click on the link below:
Fujitsu Siemens Download page. ( http://ts.fujitsu.com/support/downloads.html )
In the page put scenic p300, or put the serial, or put scenic p300 in model description.
In the following boxes select:
Personal Computer
Former Models
P series
P300
Select model in last box
In the next step you will be asked to select Windows operative system.
Select OS, then find the driver to download.
SOURCE: i want to enter BIOS
When your computer first starts up, almost immediately after you push the power button, a prompt on the lower portion of the screen (but not always lower, sometimes upper) will appear saying 'Press F2(for example) to enter BIOS, or SETUP.
You don't have very long to press the button, as the screen will change quickly, but the most common bios entry hotkeys are Del, F2, F10 or F12. Hope this helps.
SOURCE: I will reset the password of bios (pc
There is a jumper on the motherboard that has 3 pins put jumper on other side for 5second and then put back with the power turn off.Or remove battery for a couple of minutes. That will reset the Bios.
Testimonial: "Thank you it is correct. excuse me for my english."
