Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
try going into the menu 8 clicks down onto the af control,and make sure its on single AF ,not continuous,as if its on continuous it will keep trying to stay in focus,if this dosent solve it its probabley a faulty lens
I love your model, out of all the sets i work on i would say to keep it as long as you can. You have a simple convergence problem and its not to bad of a repair even at the DIY level. The new sets on the market these days brake about every 10months so to keep your 8 year old tv would be a smart choice. If you can solder and use a meter we can fix your set for under $100. If you call a repairman to fix it its going to run you $300-$500 depending on your area. But even at that its less than 1/4 the price of a quality new set. Remember when you buy a new set these days you dont only have to buy the tv you have to buy a stand to put it on or a wall mount (then if you mount it on the wall either you need to know how to do it or you will need to pay someone to do it) then i never would buy a new set without an extended warranty, then you have cableing to buy (most likely your going to hook it up hdmi) and so on. To put a brand new 52" tv in your house that i would reccomend after its all said and done your going to be looking anywhere from $2500-$3500. Hope this is the info you were looking for. any more questions, or if you want to try the repair yourself just ask!!
