Question about Orange SPV M1000
What does an orange light on micros e7 terminal mean?
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
New blower motor and new resistor. Blower motor still not working. What do I check next?
switch. Use a 12 volt test light at the resistor connector. Take connector off resistor, check the brown/orange stripe wire for 12 volts--is it hot? if yes, connect your test light clip to that terminal and probe the other terminals. Orange/black wire terminal should light up with setting on high. Black wire terminal should light on any setting, etc.
If brown wire with orange stripe is not hot, check fuse 9.
If fuse 9 is OK, problem may be in the mode selector switch.
See diagram and let me know if you have any questions.
Dec 23, 2010 | 1989 Mercury Topaz
Orange TT. cuts out on high gain on both channels, what can be the problem?
You MAY be exceeding the capability of the unit causing the thermal protect of the PA chip to shutdown. A 15 Watt amp is NOT going to make a lot of noise unless you have super-efficient speakers that are say 15 inch ones in decent cabinets. You still will be limited in sound level. Just because the gain control goes to a paticular number doesn't mean the amp can take it !!! Mpost of these use 7 terminal amp chips about the size of a TO220 transistor. Heat sinks are OFTEN very inadequate.
May 27, 2010 | Orange Amps Orange Amplifiers Tiny Terror...
I have 1993 dodge dakota 3.9l v-6 with trouble codes 12,15 and 55 what do they mean
the trouble codes are as follows code 12 problem with battery connection. direct battery input tp pcm disconnected within the last 50 ignition key-on cycles. code 15 a problem with the vehicle distance/speed signal. no distance/speed sensor signal detected during road load conditions. code 55 completion of fault code display on check engine light. this is an end of message code. the speed sensor is located on the transmission/transfer case extension housing. check plug connection to speed sensor for power using an volt meter. connect the positive side of volt meter to the orange wire terminal and the negative side of volt meter to the black/light blue terminal. the voltage should be approximately 8.0 volts and to check the voltage from the pcm connect the positive end of volt meter to the white/orange wire terminal and the negative side ti the black/light blue wire terminal. signal voltage should be 5.0 volts. if there is no signal voltage signal, have the pcm checked out. if you have both signals from the terminals then remove the vehicle speed sensor and check the speedometer pinion for worn or missing teeth.
Apr 07, 2010 | 1993 Dodge Dakota
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
U3 2.0GB USB 2.0 Sandisk Cruzer micro opearation prob
I hate to say it but sounds like the drive is dead.
Typically the LED should go green. If it does not it could be the drive is bad or not talking.
Might have to check the Sandisk site for information on this one. Most times when I have an orange light here, that means "it's dead"
Jan 26, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Orange SPV M1000 Logo
Top Orange Computers & Internet Experts
Ekse
Mufaddal  Kurlawala
Mufaddal Kurlawala
ray gallant
Are you an Orange Computer and Internet Expert? Answer questions, earn points and help others
