Question about Rival VS107 Seal A Meal Vacuum Food Sealer
My rival vs107 will not seal nor does the hands-free light come on
How do i get the sealer to seal and the light for hands to come on
1 Related Answer
Anonymous
SOURCE: Had a Rival VS110 Seal-a-meal vacume good sealer
you have to push down with a lot of force to get the rubber seal to give enough to allow it to latch...
Posted on Nov 28, 2010
My rival seal a meal does not vacumn the air out when it is sealing. what is the problem and how do I fix it
There is air leaking in somewhere. Make sure there are no wrinkles in the bag at the sealer location. Also, make sure the seal on the bottom of the bag is complete or the machine will simply suck air from the bottom and out the top. Make sure there are no food particles stuck in or to the sealer mechanism.
I don't have a Rival but have a Foodsaver vacuum sealer. If I have trouble getting the air to vacuum out, I remove the black foam seal from the machine, run it under water for a minute, shake off the excess, and reseat the seal. For some reason, the water helps create a seal. It also helps remove food that may have leaked onto the foam seal.
If the wire that heats and melts the bag is damaged, it may not be sealing the bag completely.
Jun 06, 2016 | Rival Kitchen Appliances - Others
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Dec 25, 2015 | Kitchen Appliances - Others
Do they make special bags for this unit
They do! You can get them on the Seal-A-Meal website or even on Amazon. Here's a link.
Vacuum Sealers Accessories
Nov 20, 2015 | Rival VS107 Seal A Meal Vacuum Food Sealer
How does the top of the machine snap shut? Is it supposed to snap shut before sealing? How do I seal the bottom of the plastic sheets so that I can seal the rest of the plastic sheet?
You seal the bottom then pull out the length you need, insert food and vacuum and seal the top. In other words, the top of one bag becomes the bottom of the next one.
Feb 27, 2015 | Rival VS107 Seal-A-Meal Vacuum Food Sealer
Nedd the new tape for a seal a meal machine, rival
dated: Wednesday, November 20th, 2013
Call:
Rival Customer Service at 1-800-557-4825
Nov 13, 2013 | Rival VS230 Seal A Meal Vacuum Food Sealer
Seal-a-meal food storage system
You can buy the replacement part on KMart's website.
Jul 04, 2012 | Rival VS107 Seal A Meal Vacuum Food Sealer
Unit will not heat and Hand free light will not come on.
My husband is a fisherman and swears by his vacuum sealer, but he was about to trthrow it through the window last week when it stopped working.
The motor would just run and run, but the vacuum never kicked on.
I found an answer online that solved his problem - apparently, it's all about bag placement.
When you're just trying to seal one end to make a bag cut from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Apparently, the machine was sucking, but air was constantly come through the other, open end.
Once you've sealed a bottom into your bag and have added your contents, then you put the open end (after making sure it's dry) all the way into the vacuum tray.
Hope this helps, good luck! I was so happy to find an answer online that I figured I'd share it with others.
Here's to fresh fish!
Oct 24, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
Need upper and lower sealing gaskets for Rival Seal-A-Meal VS107
I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012)
Sep 02, 2011 | Rival VS107 Seal A Meal Vacuum Food Sealer
Rival VS107 Seal A Meal Vacuum Food Sealer Logo
91 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
