THE ICE MAKER MAKES ICE BUT IS NOT DISPENSING. IT SEEMS THAT WHEN YOU PUSH THE DISPENSER, IT IS NOT "TALKING" TO THE ICE MAKER
SOURCE: RS21DCNS water dispenser isn't dispensing.
your fridge is slowly icing up, you'll next notice the fan being noisy. read this article and ring samsun on the free phone number
http://www.bbc.co.uk/consumer/tv_and_radio/watchdog/reports/consumer_goods/consumer_20080407.shtml
SOURCE: Ice Maker Not Dispensing
I have fought with ice makers before and I find it to be easier when considering the time and trouble dedicated to troubleshooting and frustration of not having ice when you want it, to just replace the unit. You can purchase a replacement Ice maker for your fridge on-line for $85.00 plus shipping and handling. At the most you will have to remove 3 screws and unplug one electrical connection (please remember to unplug your fridge before attempting replacement) and your ice troubles will be over.
SOURCE: Ice maker in freezer fills up but won't dispense
some ice makers have heating elements in the trays to melt the ice away. that way it will despence.element could be bad.
SOURCE: water dispenser
Can you pull you refrigerator away from the wall and carefully remove the cover over the area where the water feeds the refrigerator. There should be a set of plugs one for dispenser and other for the ice maker. Make sure both sides are plugged into the dual water control valve. I did try to pull your model number up so I could help you better, but the model number above your post goes to an oven. Maytag and Samsung sometimes places parts in places that are hard to point out. Tis could also be a dispenser lockout. If you find the problem this would be something that commonly happens an assembly line. If you find the correct model number I will send you a service manual. Either way I am here to help, Thanks,Sea Breeze
SOURCE: My samsung RF266 stopped running
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
