Question about Magic Chef MCWC30MCG Compact Wine Cooler
My wine cooler freezes everything
The temperature just flashes LL and the temperature goes up and freezes everything pop beer and frost on back of cooler.
  • Tom Mamay Feb 15, 2019
    did you ever find out what the fault FF was....I have it now on mine..:(
1 Related Answer
Lee2fixit
  • 218 Answers
SOURCE: wine cooler
Try this website. http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=224777abd6c75c24622a757a6f5ff1ba&q=Magic+Chef+MCWC30MCG&e=1
Posted on Jul 27, 2008
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Thermostat on wine cooler
Well, I'm not sure what your actually trying to do, but the whole purpose of a wine cooler is to cool, not to freeze and the temperature should really get no colder than 34 degrees F.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 19, 2012 | Refrigerators
Why is there water in the bottom of my wine cooler
cos you have condensation inside due to the fact that it is not frost free OR you have a seal leak.....OR the door is constantly open and closed (my beer fridge is like that.....)
Jun 25, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Can't change the cooler's temperature? the temperature reads LL and its very cold.
LL is an error code which means that it is too cold. Surprised that it didn't freeze something. Problem is likely the thermostat ($15 - RF-7350-55) or motor control board ($50 - RF-0668-04).
Nov 21, 2009 | Haier BC112G Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
235 people viewed this question
Top Magic Chef Furniture Experts
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
