SOURCE: Epson Stylus Photo 1290 InkJet Printer
This is a maintenance request. Basically the internal counter has hit it's limit and now requires that the counter is reset and the ink pads are replaced or cleaned.
Ask at http://www.TheServiceManualShop.com if they do a Rescue Kit for your machine. This should include all the goodies you need to get running again. If they have no kit for machine, let me know as I may have an alternative.
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
SOURCE: Epson 1290 Head Cleaning
Just download the software from Epson's site. I don't think there's anyway to run the utility from the buttons, I'm afraid.
SOURCE: MY EPSON D88 PRINTER HAS 2 FLASHING LIGHTS
This is usually caused by a problem with the chip(s) on the new cartridge.
Check that the chips are clean, and are correctly installed on the cartridge(s) (some can be knocked out of alignment and thus not connect properly).
Also check for any damage to the tiny wires in the printhead where the cartridge sits.. These can also become soiled with fluff, etc... Be VERY careful if you try to clean these as they are very delicate and if broken off you will have a broken printer.
Last thing is of course to check you have the correct cartridges... A common one with the D88 is to have C86 cartridges which are not compatible at all (different' chips!).
Hope that helps.
SOURCE: Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
