Question about Amana SXD524VW Side by Side Refrigerator
Side by side refrigerator freezer warm - Amana SXD524VW Side by Side Refrigerator
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
SOURCE: Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Posted on Sep 18, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Posted on Feb 19, 2009
Anonymous
  • 614 Answers
SOURCE: amana side by side refrigerator not cooling
You have bad defrost timer or bad heaters. Most of the time the problem is heaters. You have to completly thaw unit and install the heater. You may need a service tech for that but get model and serial numbers. Go to appliace sore and buy the parts yourself. Save you some money.
Posted on Jun 12, 2009
Anonymous
SOURCE: The refrigerator is running but not cooling
I did check the fan and it was not operating and checked the voltage to the thermostat it was good and replaced the stat. It is working now.
Thank you
Todd
Posted on Jun 18, 2009
SOURCE: Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Posted on Jul 07, 2009
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Freezer is cold. Refrigerator side is too warm even on the coolest settings. What do you suggest I do?
freezer is cold. Refrigerator side is too warm even on the coolest settings. What do you suggest I do?
Nov 25, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Refridgerator side is getting warm
the refrigerator side of most modern day units only gets cold by cold air being blown over from the freezer side so check the fan in the freezer to make sure it is working as well as check the damper that opens and closes to let cold air over to the refrigerator side
Apr 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer way too cold, refrigerator side too warm on side by side.
This can be caused by lots of faults first inspect the evaporator in the back of the freezer for ice build up if this is the case the defrost system has a fault, if not the unit that opens between the wall of the freezer and the fridge may be faulty check for the grills opening and closing
May 29, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
Amana SXD524VW Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
