Question about Krups Kitchen Appliances - Others
Model tt617050 stainless two slice toaster/each slice of bread only gets toasted on one side and takes a long time to toast bread. why all of a sudden could this happen, need help please
SOURCE: one slot only toast one side of the bread slice.
You may need to replace your toaster, but don't worry, just go to the following address:
http://shopping.msn.ca/results/toasters/bcatid1150/forsale?text=category:toasters
Posted on Dec 06, 2007
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
SOURCE: Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Posted on Aug 13, 2009
SOURCE: Left-hand section only toasts on one side
The heating resistor on the left side has shorted with the case. Since you don't know very much on electrical equipment (to fix it you would have to open it, remove the shorted piece of wire, reattach all and insulate them properly) and the price of a new item is low, just buy a new one and discard this one. You shouldn't use it again, under no circumstances - if you're unlucky it can kill you.
Posted on Oct 03, 2009
Testimonial: "Thank you very much for the information. I will be heading out to buy a new toaster. "
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
