Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
How can I use a stick or something similar to use in place of selector knob on bosch nexxt 500 series washer? Selector knob does not engage and refuse to pay the $483 I was quoted to replace the whole control panel...on a barely 3 year old machine.
1 Related Answer
caroldon
  • 17130 Answers
SOURCE: Bosch Nexxt 500 series washer program cycle selector knob just spins and no longer clicks in place to select a cycle. How do I fix this?
This is a failure of the program controller timer unit and it must be replaced as the locking mechanism or the stepper motor link had failed.
Posted on Aug 04, 2012
Aug 03, 2012 | Bosch Washing Machines
E27 and e95 code
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
Jul 18, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Is there any detergent I should avoid using in my Bosch Nexxt 500 Series washer?
Any clothes-washer HE (low suds) soap will do. Just be aware that you only need a tablespoon of the soap, not the 3/4 cup that comes in the box!
Oct 17, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Gasget came off the washer and i can't get it back on
I have the perfect solution the placing of the Retaining Spring back on the Bosch Nexxt 500 Door Gasket. It only took me only 5 Minutes after fighting with it for hours and getting nowhere. What I did was purchase a set of 12 inch hemostats (long Clamping Pliers). The ends of the Hemostats I wrapped both of the jaws with Electrical tape to prevent the Spring on the retainer from sliding up the jaws of the hemostat. When the ends of the retainer are placed on the ends of the jaws and the hemostat opened the spring is stretched. I found that If you use your knee to hold the hemostat open while placing the retainer in the groove of the gasket you can slowly release the springs and set the retainer back into the gasket without the gasket pulling off the tabs.
Mar 01, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch washer spin only
Had a repair man here for the same issue. Learned two things:
1. Too much detergent causes 'soap lock.' The electronics will get confused when there's too many suds left after a rinse and shut the spin cycle down. That's why re-running the entire cycle without more detergent solves the problem. Use less detergent.
2. There is a way to manually get the spin cycle to run using diagnostics codes. Here's what my guy did:
a. Washer selection knob in OFF position.
b. Hold the 'Spin Selection' and 'Delay Start' buttons down at the same time.
c. While holding those two buttons, turn the Washing selector knob to Permanent Press-Cold.
d. Keep the buttons held down until the LCD control panel reads 'P:01'
d. Release buttons.
e. Use the 'Spin Selection' button to cycle thru the codes. Stop when it reads 'P:04' which is the spin cycle.
f. Press 'Start/Pause' button to begin the spin cycle.
I don't know what the other codes do but this should save you from having to run the entire wash cycle.
Hope that helps! Tim
Apr 17, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
67 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
