Whirlpool GBD307PD Electric Double Oven Logo
B
Bob Engel Posted on Jun 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool range, model RF386PXGQ has had the display go blank. Everything works and if Itouch a button the display comes back on for a while. Can you help?
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Jun 04, 2014
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
258835
Points
4510
There may be a loose wire at a connection point.
My Whirlpool Double Oven rdb305pds14 had a blank display. On this page it was suggested to replace the board, which I did. My question is why now is th
Hi Billion Johnston!
Maybe the ribbon cable from the keyboard to the board is not correctly connected or is rusted in one of its terminals, avoiding making contact only to those tracks that goes to the "Off" button. Removing it, checking and cleaning the contacts with rubbing alcohol in a cotton swab may help.
Hope you may repair your oven!
I hope you may have found this answer helpful!
Best regards,
Miguel L. Martins
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
2answers
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
My whirlpool range model#rf114px513 started
You will need to press the stop /cancel button this will clear the display
Nov 15, 2009 • Ovens
2helpful
The display is blank, yet the light comes on. The
i'm assuming everything works but you cant see the clock?
if this is the case then you need a new clock board.
very common on these wall ovens
2helpful
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
2helpful
3answers
2answers
GE JCB909 Range - Blank display
suspect wrongly wired from new
Jun 25, 2008 • GE Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
