SOURCE: canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
SOURCE: Need manual for canon laser class 2060P super G3
I need to be able to change the fax # so when I fax a document that it will show the reciving party my new fax # . And or I need a Manuel for this machine
SOURCE: the paper feeder of my canon super g3 jams every time
Yes, there is an easy solution, possibly. Mainly because you say it may do a single job, and then it keeps jamming. Do you see the second sheet jamming in when it is not called for? Anyhow, you may try cleaning the rollers, all of them, like I did here: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html This completely solved my problem of persistent paper jams.
SOURCE: Canon super G3 Fax display message continously "Check paper size"
my fax give the message "check paper size" I' clean the all sensors' end nothing
Sometimes turning it off and on again fixes it. However, we started having a problem where it would print out one page after you powered it back on again and then give the "incorrect paper size" message. I've found that by either holding down the green button or repeatedly pressing it while it powers back on (and held until the first page prints) fixes the problem.
