Question about Ipcw 2004 Chevy Impala - All Impala models - Headlights
How to replace missing connector to headlight assembly on 2004 Impala
Someone cut the connector to the right headlight assembly on a 2004 chevy impala, I purchased a new connector assembly, I need to know which wires on the connector connect to the existing wires coming from the harness. Wires coming from the harness are color coded, wires on the new connector are not.
Posted by Ken Schein on
Paul Smith
    Habit-Forming:
    New Friend:
  • 56 Answers
Compare the wires to the other side. ; )
Posted on Jun 05, 2014
2001 Chevy impala passenger headlight frequently needs replacement
Yes, it sounds like there is a fault. The services of an auto electrician might benefit you. It will be difficult for you to diagnose without test equopment.
Jun 02, 2015 | Ipcw 2001 Chevy Impala - All Impala models...
I own a 2004 chevy impala my headlights jus stopped working but no blown fuse or headlight.
Fuses are good, replace the turnsignal switch. All the exterior lights run threw it.
Feb 27, 2015 | 2004 Chevrolet Impala
Shortage 2006 impala headlights
check the connector behind the headlight assembly to see if its loose.
Jul 08, 2014 | 2004 Chevrolet Impala
Headlight assembly connector color code and wiring diagram for 2004 impala
Test it. Try all the sequence below until it match all three wires. Don't worry, it won't spark if the wire will not match the right wire.
Jun 04, 2014 | Ipcw 2002 Chevy Impala - All Impala models...
My 2004 Chevy Impala right head light won't come
There are right and left fuses for the headlights. The dimmer switch and headlight switch provide the ground circuit.
Do you have power at the fuse ?
Feb 15, 2013 | Cars & Trucks
Where is the headlight relay on 2006 ss impala
GM does not use a headlight relay, the switch contains a safety cut off switch to avoid short induced fires. You likely have a defective main light switch and the connector to it is also burnt.
Apr 21, 2012 | 2004 Chevrolet Impala
Change headlight assembly 2004 chevy impala
There are two white plastic slide clips, one on each side, that you must pull up on with your fingers to release the whole module assembly. Good luck!
Aug 14, 2010 | 2004 Chevrolet Impala
How to install front turn signal 2004 Chevy Impala
Once you open your hood look on the back of the headlight assembly. Twist the connector on the back of the turn signal and the bulb will come out. Then just replace with the correct bulb twist it back in and then test the blinker.
Apr 27, 2010 | 2002 Chevrolet Impala
2004 chevy impala no headlights
there's a button on the right side of the steering wheel that says serv push that button. It's put right there for when they use them as police cars you can cut the headlights off. You will probably notice that dash lights are on.
Jan 15, 2009 | 2004 Chevrolet Impala
Replace the single light bulb on my 2001 Chevy Impala front
THE CORNER LAMP? next to headlight? there is a philips screw on top of light assembly will see it when you open hood remove screw and light will come out
Dec 10, 2008 | 2005 Chevrolet Venture
Ipcw 2004 Chevy Impala - All Impala models - Headlights Logo
133 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
gbob59
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
