Question about Ipcw 2002 Chevy Impala - All Impala models - Headlights
Headlight assembly connector color code and wiring diagram for 2004 impala
I have to replace the connector to a new right headlight assembly on a 2004 chevy impala, someone cut the original connector off and I do not know which wires from the harness go to which wires on the connector.
Posted by Ken Schein on
Rudolfo Lanuza
    Problem Solver:
  • 25 Answers
Test it. Try all the sequence below until it match all three wires. Don't worry, it won't spark if the wire will not match the right wire.
Posted on Jun 05, 2014
2003 impala headlight connector diagram
Test the connector, you do not need a diagram, one wire is hot when low beams are on, two are hot for hi beams and the last is a ground.
Jul 27, 2018 | Cars & Trucks
2001 Chevy impala passenger headlight frequently needs replacement
Yes, it sounds like there is a fault. The services of an auto electrician might benefit you. It will be difficult for you to diagnose without test equopment.
Jun 02, 2015 | Ipcw 2001 Chevy Impala - All Impala models...
I need to see a diagram on how to replace headlight harness connector that is located inside the headlight on 2004 chrysler crossfire
Pull the rubber dust cover back you will see the electrical wires going to the bulb you can pull the old connector off from there it is not inside the housing, the bulb is held in by a small spring clip at the back of the bulb socket.
Sep 06, 2014 | 2004 Chrysler Crossfire
Shortage 2006 impala headlights
check the connector behind the headlight assembly to see if its loose.
Jul 08, 2014 | 2004 Chevrolet Impala
My 2004 Chevy Impala right head light won't come
There are right and left fuses for the headlights. The dimmer switch and headlight switch provide the ground circuit.
Do you have power at the fuse ?
Feb 15, 2013 | Cars & Trucks
Where is the headlight relay on 2006 ss impala
GM does not use a headlight relay, the switch contains a safety cut off switch to avoid short induced fires. You likely have a defective main light switch and the connector to it is also burnt.
Apr 21, 2012 | 2004 Chevrolet Impala
How to change the headlights?
Hi there, here are some few tips to assist you:
  • Remove the center cover and the screws attached to the radiator grille. Pull the radiator grille out of the engine compartment and set it on the ground.
  • Use a T30 Torx screwdriver to remove the two primary retaining screws from the headlight assembly. Make a note of each screw's original location--they're not interchangeable, so you'll need to put them back in the right slot to reassemble the light.
  • Draw the headlamp assembly away from the car and then disconnect the electrical wiring connector.
  • Release the wire clip on the back of the headlight assembly and remove the cover.
  • Disconnect headlight electrical connector and turn the bulb socket counterclockwise to remove it from the assembly. Install the new bulb, replace the cover and reattach the electrical connector.
  • Reconnect the headlight assembly wiring connector. Test the new bulb to make sure it works before replacing the retaining screws and radiator grille.
Hope these help. Please rate me if they do.
Jan 08, 2011 | 1999 Mercury Cougar
Ipcw 2002 Chevy Impala - All Impala models - Headlights Logo
501 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
gbob59
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
