Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
What is causing first two lights on Indesit IDL 40 dishwasher to flash when I have cleaned and changed the drain pump already?
Hi - Dishwasher broke down while being used by someone else - so we don't know if they mistreated it. It wasn't that old first two lights flash and it doesn't drain. After checking many sites and the consensus being to clean the drain pump, I did this several times, (initially it seems to work but then it stops, presumably at the stage when it would normally drain). Then I bourght a new pump and had to fit the new style electrical connections and after all that it still stops part way with the two lights flashing! I would love some good advice. Thankyou.
Posted by Beckie Anne on
3 Related Answers
Anonymous
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Posted on Sep 23, 2007
Anonymous
  • 236 Answers
SOURCE: indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
Posted on Feb 16, 2008
Anonymous
SOURCE: Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Posted on Oct 06, 2009
Indesit IDL 40 slimline dishwasher does not drain completely
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
1helpful
Dishwasher fault codes
the heating element is probably bad.
i have a idl 600 here in naples italy and it would fill up and go into alarm light 2 and 4 and pump out the water.
heating element cost 28 euro and i changed it out.
had to change the clamps as well.
if you ohm the element it should show about 100 ohms.
if it is open its bad.
the mother board does some checks and if anything fails it alarms out and drains the water after a few minuts
ralph
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
3helpful
2answers
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
3answers
Indesit IDL 40 Slimline flashing lights
the problem you have got with the flashing lights is that its the rinse aid or in need of more salt, hope thats sorts it for you
Indesit idl 705
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
