Question about Hotpoint 6.92 cu. ft. / 196 liter Upright Freezer FZA80
Hotpoint FZA 80 Red light keeps coming on - Hotpoint 6.92 cu. ft. / 196 liter Upright Freezer FZA80
Posted by nigel on
Ilia Bichin
  • 173 Answers
It means there is a temperature problem. It is a warning light
Posted on Jun 05, 2014
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
the flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
Feb 26, 2017 | Hotpoint Freezers
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
High temperature light keeps coming on
dear sir/madam please make sure your freezer,s door all is close and watch if its light coming again then there is one componennt temretuture sensor its needle need to reset or change.
hope problem will be solve.
thank you
Jul 09, 2010 | Hotpoint Freezers
Hi. the red light has come on?
press the fast freeze button. Red light usually indicates the temperature has dropped below required level. Perhaps you have put some new stuff in to freeze
Sep 30, 2009 | Hotpoint Freezers
My Upright freezer Hotpoint Product code 755703
My FZA 84 regularly has to be defrosted as it overheats.We do this by taking off the back panel - as shown by the Hotpoint service man here in Dublin. We use lukewarm water or a hairdryer to defrost the buildup of ice. Why its building up is anyones guess.The repairman suggested we might be leaving the door open but we certainly aren't. I'm very disappointed with the product and I wouldn't be purchasing Hotpoint again.
Jul 21, 2009 | Hotpoint Freezers
FZA 81 FREEZER-blocked drain
take back panel off inside freezer and you will probably find drain blocked by ice. melt off with a hairdryer and follow up with hot water till it flows freely away. takes a bit of patience
Aug 31, 2008 | Hotpoint Freezers
HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Jul 28, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint 6.92 cu. ft. / 196 liter Upright Freezer FZA80 Logo
421 people viewed this question
Top Hotpoint Freezers Experts
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
deton8 von Splosion
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
