It sounds like your "code" key may be stuck down. See if it is lower than the other keys. Check for a paper clip or staple under the key. Depending on how the keyboard is made you might be able to spray contact cleaner under the key to get it unstuck. I would bend a paper clip with a small bend at the end (90 degree angle) and use it to gently move the key up and then use my finger to press it back down. Do this several times after spraying contact cleaner under the key. Hope this helps.
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
SOURCE: NEED MANUAL FOR SMITH CORONA SL 8O TYPEWRITER
You can find it on google.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: Smith Corona 300 DLE--toggle from italics to normal type
SMITH CORONA TYPEWRITER 250 DLE. HOW DO I SPACE 1 AND HALF FOR TYPING?
SOURCE: I need a manual for a Smith Corona Model NA3HH
Google Will Repair in dunkirk NY they may be able to help.
DickyO
SOURCE: My Smith corona typewriter types the wrong characters.
Check to see if you are in KBII or a language mode if not look for bent or broken spokes on the printwheel.
DickyO
