Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Lcd screen not working on sony dcr hc 42e
I have the same issue...my camcorder's lcd screen stopped working all of a sudden.....from the forums i came to know that its an ongoing problem for HC 42 models...donno is there any solution available from sony
Posted by Vipin Jos on
  • 9 more comments
  • wristy Nov 09, 2007
    I also have the same problem with my SONY DCR HC42E. Now i am using it with the help of viewfinder. Other functions are working properly except the LCD screen.
  • Anonymous Nov 15, 2007
    Yes I too have the same problem
  • Anonymous Nov 25, 2007
    suddenly my lcd screen is off while view finder is working
  • Anonymous Dec 08, 2007
    yellow sdreen
  • Xtrmnator Dec 20, 2007
    I have the same problem... my Sony DCR-HC42 is fine except for the LCD Display
  • Anonymous Apr 09, 2008
    in my camcorder its lcd is not working from couple of weeks. is there nay solution.
  • toxzic28 Apr 09, 2008
    hc-30, screen works but touch screen functions not working. Can not access menu or settings. zoom button functions ok
  • rajeshprane May 12, 2008
  • Anonymous Oct 24, 2008
    my sony DCR-HC42 lcd screen stopped all of a suden
  • a_barone Dec 06, 2008
    I have the same problem, the LCD suddently become red-brown and then it stops working but the touch screen works... I tryed to reset but nothing happens... I'll take it to the service tomorrow...
  • roger785 Dec 16, 2008
    My unit is also having this Reddish Brown LCD problem, I called the service department, they said it'll cost me $200 to fix it. That's it, I won't buy a Sony Camcorder again, this was the 2nd one I had.
Anonymous
MY CAMMCORDER'S LCD, MODEL NO. DCR-HC42E,IS NOT WORKING
Posted on Dec 11, 2008
Anonymous
My screen has stopped working but touch screen function does work! Annoying
Posted on Aug 04, 2008
Anonymous
  • 3 Answers
Http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV33&news_id=161
You may have to check out your model of camera but it sounds like the same issue my sony camcorder had. Service is free until Sept 2008.
Posted on Nov 27, 2007
Anonymous
  • 169 Answers
The flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
Posted on Nov 05, 2007
3helpful
When I turn on my handycam sony DCR-HC 35,the touch-screen don't work!? What can I do about it?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
3helpful
2answers
Lcd problem
This problem is due to damaged of flexible board which connects LCD with the main board,
The part number and description is given below:
Part number 1-864-761-11 Description FP-185 FLEXIBLE BOARD figer is also for your convenience.
Thanks for using fixya.
1helpful
My computer does not detect my sony dcr hc 42e camera
Go to Camera Menu, find USB Stream, enable it and PC will detect camcorder.
2answers
DCR HC-42 LCD screen problem
Hi i had the same problem and i got it for the second time. can i please know how to remove the camera so i can replace the strip my self. And do u have a service manual. if so can i know where to get one for my self. thanks
LCD and view finder not working
Well I saw on other post you can turn the screen outwards. It is very difficult to use....but you have to do what you have to do. For the view finder I am still searching for an answer..
Sony DCRHC 42E handy cam LCD problem
problem on ur l.c.d strip (lcd fpc ) u chaing this one
Camra not charging battery & nither detected by computer
sounds like you have either a loose or not fitted correctly strip connector.possibly when opened for repair was not put back together properly.
2answers
LCD is not working
Hello, in order to repair this Camcorder you should replace the LCD panel flexible cable FP-185 and the plastic hinge cover. If you need more info please advice. Best regards. Arpi
6helpful
3answers
LCD display is not working
the flex wire of lcd monitor has being cut.....and a message 'cover is not open' there switch inside the cover of the lens that is losing contact....
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Ekse
Jax Planet
Jax Planet
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
