Pure Digital The Bug DAB Radio Logo
G
Graham Bennett Posted on Jun 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bauhn ADR-6R How do I preset radio stations ? as the instructions in the manual don't work?
M Neill
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 10, 2014
M Neill
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
691
Points
I just bought one yesterday and the procedure in the manual worked for me. The trick is to press and hold the Preset button as the first part of the process. (Don't just quickly press it - this won't work).
Les Davis
Level 2:
Sergeant:
  • Expert 247 Answers
  • Posted on Jun 05, 2014
Les Davis
Expert
Level 2:
Sergeant:
Answers
247
Questions
Helped
36525
Points
622
Manually tune to a station and hold a knob until it beeps. Do the same for all presets.
1helpful
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
I purchased a 2004 Mitsubishi Endeavor without an owners manual and i don't know how to change the radio station presets!
most cars you just tune the station you want, then hold the preset button (that you want the station at) in until it beeps .
1helpful
3answers
How do I set the presets on my radio. I don't have a manual and can't figure it out
start the car turn the radio on scroll to the station you want then push and hold the preset button 1 thru 9 untill it beeps then go to the next station you want to set and do the same.
1helpful
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
14helpful
2answers
LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
4helpful
2answers
Preset Radio Statios
I just dug out the manual and have now programmed a preset.
Instructions:
1) Make sure there are a pair of working AA batteries behind the second (inside) compartment door as these power the memory (mine were Duracells with an expiry of 2001 and had worked all the way through to 2010 before finally failing!)
2) Find the frequency you want with the Up/Down button
3) Press the M button - you will get a flashing M on screen
4) While the M is flashing, press one of the numbered preset buttons.
1helpful
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
5helpful
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Top Pure Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Pure Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
