Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Tony Bullock Posted on Jun 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Liftmaster motor whines for 3 seconds then trips off
The lift master garage door opener .when try to open it with remote . the motor will make a humming noise for 3 seconds then immediately cut off
T.l. Moore
Level 2:
  • Expert 273 Answers
  • Posted on Jun 06, 2014
T.l. Moore
Expert
Level 2:
Answers
273
Questions
0
Helped
426242
Points
726
There are three possibility's first one is a bad run cap on the motor you would have to remove the cover and unplug unit and look for the cap see if its blown apart or bulged . or it may have just opened and be defective
the second is that it's jammed and the motor is going out on a thremal over load to protect the motor . you could try pulling the emergency release and try it one it resets its self . the third is that the motor has a shorted winding on it and will require replacement . at that point it most likley would be more cost effective to replace the opener
1PC Medic
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jun 05, 2014
1PC Medic
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
2792
Points
15
It is either a problem with the lower limit screw/switch or the capacitor that gives the motor the jolt to get started.
Randy Fitz
Level 2:
Scholar:
  • Expert 112 Answers
  • Posted on Jun 10, 2014
Randy Fitz
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
73294
Points
399
Likely failure of the lift springs on the door mechanism-- not a problem of the Liftmaster. Try pulling the release and lifting manually-- that will show you if the door cannot be lifted, where the problem lies-- with the door mechanism.
5 Related Answers
Anonymous
  • 3197 Answers
  • Posted on Jun 07, 2009
SOURCE: motor hums but door will not open
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. The part number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Anonymous
  • 11 Answers
  • Posted on Jun 24, 2008
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Anonymous
  • Posted on Dec 16, 2008
SOURCE: Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Anonymous
  • 3197 Answers
  • Posted on Jan 09, 2010
SOURCE: My Liftmaster GDO makes a clicking sound and won't open
See if the trolley is jammed against the bolt just in front of the motor unit. If so remove the bolt and then run the opener until the door is closed. While the door is closed locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Remember to replace the bolt.
Anonymous
  • 3197 Answers
  • Posted on Jul 13, 2010
SOURCE: How do I tighten sagging garage door chain?
I think you have more problems than just a sagging chain. It is most likely sagging because the bronze bushing at the gear and sprocket assembly is bad. It lets the sprocket lean forward and loosens the chain. You will also need to remove the cover from the motor unit and check the drive gear. It is a white gear just in front of the motor and is most likely stripped.
1helpful
2answers
Lift-Master 1260, circa 1993. Today it won't open or close. Just lights on and a quiet clunk sound when I press the remote or wall button. Chain doesn't move. Safety sensor lights steady green. Unplug for...
29 years is along run on an opener. Personally I would replace it and not spend any money trying to repair it. You can try and find a control panel, or buy a new opener for $200.00 at HD. you can leave track in place replace rollers from new opener box.
2helpful
2answers
I need a remote keypad for 41a5021-1e lift master. What model will work for this unit
check the liftmaster web-site. also any garage door sites may have parts offerings. google the part number as well.
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
13helpful
Master lift remotes suddenly won't work. Wired panel button works opening and closing door.
Make sure the light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds.
1helpful
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I need a remote for a Lift Master Professional ...
The model number will be on the opposite end of where you found the part number you listed. You can then call any Liftmaster dealer listed in your yellow pages.
Had to push green reset button on 1/3 hp garage master motor
pushed it too long. push 1 second and recode keypad. you wiped out codes by hitting for 6 seconds or more
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
