Question about Creda W120VW Front Load Washer
My door has come off leaving two white things that are still on metal hinge but they are not broken
SOURCE: creda simplicity 1000 door hinge
I had the same problem and got a new one on ebay
Posted on Jan 16, 2008
SOURCE: washing machine door hinge
I cant find much on this unit. the back can be remove but will likely not help you .
remove the top access panel ,
remove the front control switch panel.
then you can remove the whole front door and all.
its really not that hard just be careful of the plastic items.
Posted on Feb 27, 2008
SOURCE: Door Hinge replacment
have you tryed taking the door screws out and put the new one in
Posted on Apr 02, 2008
SOURCE: the hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Posted on Nov 28, 2009
