HP Photosmart 2575 All-In-One InkJet Printer Logo
A
Angela Sierra Posted on Jun 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not get my my HP 7525e to scan - HP Photosmart 2575 All-In-One InkJet Printer
Daryl Gleaton
Level 3:
  • Master 749 Answers
  • Posted on Jun 04, 2014
Daryl Gleaton
Master
Level 3:
Answers
749
Questions
0
Helped
234361
Points
2170
Yty reinstalling the printer driver, if that doesn't work than uninstall fom control panel and reonsall software for printer. First try turning it off then back on. This will reconfigure the printer.
I am out of ink cartridges (none in the printer) but I just want to scan something...how can I do this?
You can still scan using either the command menu on the scanner or the HP software from you computer. As long as you are not trying to print, having no ink should not effect the scanning.
If you have the HP solution center software, you can open that application and pick scan a document or scan a picture.
From the PSC 1610v controls follow these directions:
Scan to an application
You can scan originals placed on the glass directly from the control panel.
1. Load the original face down on the right front corner of the glass.
User Guide 59
Use the scan features
2. In the Scan area, press Scan To.
The Scan To menu appears. The Scan To menu lists destinations, including
applications, for anything you scan. The default destination is the one you
selected the last time you used this menu.
The Scan To menu can be configured. You can designate which applications and
other destinations appear on the Scan To menu by using the HP Image Zone
software on your computer.
3. To select an application to receive the scan, press until the destination you
want appears on the control panel display, and then press Start Scan.
A preview image of the scan appears in the HP Scan window on the computer,
where you can edit it.
For more information about editing a preview image, see the onscreen HP Image
Zone Help that came with your software.
4. Make any edits to the preview image in the HP Scan window. When you have
finished, click Accept.
For more information on editing a scan in the HP Scan window, see the onscreen
HP Image Zone Help.
The HP All-in-One sends the scan to the selected application. For example, if you
chose the HP Image Zone, it automatically opens and displays the image.
If you don't have the HP solution center, you can download it from this link:
http://www.hp.com/global/us/en/consumer/digital_photography/free/software/photo-creations.html
If you found this answer helpful, please remember to leave positive feedback.
How to scan
Here is the manual:
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
Page 45 will give you the scanning instructions.
1 Load your original face down in the right front corner of the glass.
2 In the Scan area, press the Scan To button.
The Scan To menu appears, listing destinations, including applications, for
anything you scan. The default destination is whichever one you selected the last
time you used this menu. You designate which applications and other
destinations appear on the Scan To menu by using the HP Image Zone on your
computer.
3 To select an application to receive the scan, use or to select it, and then
press OK or Start Scan.
4 Make any edits to the preview image in the HP Scan window. When you have
The HP all-in-one sends the scan to the selected application. For example, if you
chose the HP Image Zone software (Windows) or JPEG to HP Gallery
(Macintosh), it automatically opens and displays the image.
How to scan using hp j4550 with vista os
Scan with HP software in Vista
Scan without using HP software in Vista
Scanning without using HP software should be used as a fallback, or for troubleshooting certain problems. HP has full-featured software for your product and the Vista OS (recommended).
When I touch the Scan Menu button, and choose scan to computer I get a message that states: No Scan Options I have been scanning for a year. This happened suddenly and I can't figure out why
Hi
Thanks for using FixYa. Due to any reason when the HP Communications process fails the HP Scan application won’t work. To resolve the issue you’ll need to follow the procedure as given below---
  1. Force Quit HP Communications (if running)
  2. Force Quit HP Scan (if running)
  3. Turn the printer off
  4. Turn the printer on
  5. Select Scan Picture from the HP Director application
  6. When the HP Scan application complains, press Reset
  7. HP Scan will then hang, but HP Communications will restart
  8. Force Quit HP Scan (again)
  9. Select Scan Picture from the HP Director application (again)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
2answers
How does the scanner work?
Simply pull the lid on the top and place the paper on it . Then close the lid and press scan button on the scanner, which will start scanning your documents.
I have the officejet 6310 but cant use the scan feature, how do I get it to work
this is how you use the scanning features of your printer.
To use the scan features, the HP all-in-one and computer must be connected and turned on. The HP all-in-one software must also be installed and running on the computer prior to scanning. To verify that the HP all-in-one software is running, look for the HP all-in-one icon in the system tray at the lower-right side of the screen, near the time.
NOTE: Closing the HP Windows system tray icon can cause the HP all-in-one to lose some of its scan functionality and result in the No Connection error message. If this happens, you can restore full functionality by restarting the computer or by starting the HP Image Zone software.
For information about how to scan from the computer, and how to adjust, resize, rotate, crop, and sharpen scans, see the onscreen HP Image Zone Help that came with the software.
Scan an original
Follow these steps if the HP all-in-one is directly connected to a computer through a USB cable.
1.
2.
In the Scan area, press Scan To . The Scan To menu appears, listing destinations, including applications, for anything that is scanned. The default destination is whichever one was selected the last time this menu was used.
3.
To select an application to receive the scan, use the arrow buttons to highlight it and then press OK or Start Scan . A preview image of the scan appears in the HP Scan window on the computer.
4.
Make any edits to the preview image in the HP Scan window. When finished, click Accept . The HP all-in-one sends the scan to the selected application.
Send a scan to an HP Instant Share destination
1.
Load the original face down on the right-front corner of the glass or, if using the document feeder tray, in the document tray.
2.
Press Scan To on the control panel of the HP all-in-one. The Scan To menu displays.
3.
Use the Up Arrow and Down Arrow buttons to highlight HP Instant Share .
4.
Press OK or Start Scan to select the destination and scan the image. The image is scanned and sent to the selected destination.
NOTE: If an original is detected in the automatic document feeder, one or more pages are scanned. If no original is detected in the automatic document feeder, a single page is scanned from the scanner bed.
NOTE: For Windows users, the HP Image Zone software opens on the computer, and the HP Instant Share tab displays. A thumbnail of the scanned image will display in the Selection Tray. For more information on the HP Image Zone, see the onscreen HP Image Zone Help that came with the software.
Stop scanning
To stop scanning, press Cancel on the control panel.
Scan to computer
Several ways to control your scanner:
From this HP link
Changing scan settings in HP Director
Scan settings include resolution, output type, and file type. These settings can be changed using HP Director.
  1. Open HP Director, if it is not already open:
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Director .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Director .
  2. In the Select Device list, select your product, if it is not already selected.
  3. Click Settings , and then point to Scan Settings & Preferences .
  4. Click the scan setting menu that corresponds to the type of file you are scanning.
    • Scan picture settings : Designed for scanning pictures, including any type of non-text image, such as a drawing, logo, or photograph
    • Scan document settings : Designed for scanning documents
    • Scan preferences : Control scanning preferences, such as automatically straightening crooked images
    • Button settings and Scan to... setup : Control the defaults for the scanner buttons on the control panel of the product
    After selecting the appropriate menu, the corresponding window opens.
  5. Change settings as appropriate, and then click OK . The scan setting window closes.
  6. Click Scan Picture or Scan Document HP Director to scan with the changed settings.
From this HP link
Using the Advanced Scanning Features of the HP Solution Center Softwaretoo large to paste - just follow the link above :)
Here the main site for the scanner - click here
Scanner will not save to computer
By default, the HP all-in-one sends all scans to the HP Photo & Imaging Gallery for you to preview. Suppose that you want to scan your photos directly to email instead. To do this you will need to modify the destination assigned to the front panel scan button. Here is how to do it:
  1. If you have not already done so, open the HP Director and click Settings , point to Scan Settings & Preferences , and click Scan to… Setup . The Button Settings dialog box appears, with the Destination List tab on top. The HP all-in-one automatically inventories your computer and lists all the possible scan destinations for you in the Available Scan Destinations list.
  2. Using our example of scanning directly to email, select the Email destination in the Front Panel Destination List and click the Move arrow to move it to the top of the listing.
  3. Click OK to save the new destination setting and close the dialog box. All of the scans you do using the HP all-in-one front panel buttons will now be sent directly to your email program, instead of to the HP Photo & Imaging Gallery.
  4. Click Scan Picture or Scan Document in the HP Director to scan using your new settings, or click a Scan button on the HP all-in-one front panel.
also
Setting a default scan profile Use the following steps to apply a scan profile to all future scans.
  1. If you have not already done so, open the HP Director and click Settings , and click Scan Settings and Preferences .
  2. Click one of the following, depending on the type of scan profile:
    • Scan Picture Settings
    • Scan Document Settings
    • Button Settings The corresponding dialog box appears. If you chose Scan Picture Settings or Scan Document Settings , the Scan Settings tab is on top. If you chose Button Settings , the Scan Button tab is on top. All of these tabs have the setting you need, Apply Scan Profile .
  3. On the Scan Settings or Scan Button tab, click Apply Scan Profile and select the scan profile that you want.
  4. Click OK . The scan profile that you selected will apply to all future scans for the scan type that you selected.
1helpful
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
k24674
Grand Canyon Tech
Grand Canyon Tech
