Locks & Locksmithing Logo
Emily Hoelewyn Posted on Jun 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a " redhead " safe and i tried to change
I have a " redhead " safe and i tried to change the passcode , and the electronic lock fell out . Can you help me , if there is any way possibly not dangerous, to open my safe .? Please.?
Thomas Smithbrother
Level 3:
Top Expert:
  • Master 3,698 Answers
  • Posted on Jun 04, 2014
Thomas Smithbrother
Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
956382
Points
10318
Take it to a lock smith.
they have ways that are not available to us.
4 Related Answers
A
Anonymous
  • Posted on Apr 27, 2009
SOURCE: I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Anonymous
  • Posted on Jan 14, 2010
SOURCE: blackspur electronic safe BB-ES100 changed
Blackspur BB-ES100 How to reset the code. Have the key
Anonymous
  • Posted on Sep 08, 2010
SOURCE: Forgot code to open hardline electronic safe
Change code to open hardline electronic safe
Anonymous
  • Posted on Feb 25, 2011
SOURCE: the electronic safe Kingavon safe
We had same problem, try putting 0000 and your code .
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
NOTE:
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
My sister locked herself out of her Justice digital safe and it is on voice mode, every time we try to reset the passcode it does not work. Does this mean that the safe is broken?
The safe would need to be open to change the passcode. Also there may be a time delay after several incorrect attempts to open. I am not at all familiar with this brand.
3answers
We don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Micromark Electronic safe
Contact the manufacturer with the model and serial numbers. They CAN supply a default passcode number.
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
