Question about Pride New Mobility Victory XL 4 Wheel Scooter
Pride mobility victory XL front tyre wear
Front tyre wear
Stuart Nimmo
    Habit-Forming:
    New Friend:
  • 88 Answers
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Posted on Jun 02, 2016
5 Related Answers
oregoon
  • 175 Answers
SOURCE: Having trouble with a 3-wheel Pride Mobility
Check that it is unplugged from the charger. Then check the freewheel lever to ensure it is in gear by placing it out of gear first, then placing it firmly in gear. Do this while the key is OFF. Wait three seconds, then turn back on and it should go.
If it doesn't, and you are sure it's in gear and unplugged from the charger, you should be getting a fault code flashing on the charger display. Consult your owners manual to determine the fault and proceed as recommended.
Here's a link to the owners manual if you've lost yours. Good luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Victory_om.pdf
Posted on Jul 11, 2009
Dan Hudson
  • 118 Answers
SOURCE: Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Posted on Nov 27, 2008
oregoon
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
oregoon
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
uxair shah
Muhammad Uzair
  • 812 Answers
SOURCE: I have no manual for my Pride Victory 4 wheel
Hello i hope u 'll be fine.... thanks for using fixya.
You can easily get the manual for Pride Victory 4
Download it and Enjoy
You can also see lots of effective information of your product from this.
  • Manual is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS
Posted on Mar 02, 2010
Pride Victory XL-4 Mobility Scooter
You can get then from Prides website
Apr 27, 2017 | Pride Health & Beauty
His I've a victory xl mobility scooter and constantly red flashing on battery meter and don't charge battery's properly can u help cheers
Hi, at a guess I would say that your batteries possibly no longer hold a charge. If the scooter has been provided for you get the organisation who gave it to you to check it over, they should service it for you.
There is a link below for the website that provides an owners manual, this may help you troubleshoot the problem
If you need anything else please post another query.
Pride Mobility Victory XL 4 Owner Manual
http://www.manualslib.com/manual/718600/Pride-Mobility-Victory-Xl-4.html
Jul 16, 2015 | Health & Beauty
Can I replace only the tire and not the whole wheel on my pride victory sport?
Yes you can. Are they solid or pneumatic tyres. You can buy from a Pride dealer or look on line. Details of tyres are written on the side of the tyre giving sizes.
Jun 08, 2015 | Pride Health & Beauty
When replacing the front wheels on my pride victory sport do I have any options? The wheels that came with it did not last very long. They were bald in four months.
do u mean tyres, if so you can fit any make to them, but if it is a front wheel drive, don't expect them to last as long as the rears, u will go through 3 or 4 sets on the front to the rear, if u got 20-30k from fronts you did well.
Hi what fuse does the victory pride xl take plz
hi ,where is the fuse you referring to lcoated , the battery one or the one located on the tiller stem ?
Regards
Rob
www.gewizrepairs.co.uk
May 23, 2014 | Pride New Mobility Victory XL 4 Wheel...
How do i get the manuals that came with the scooter.
Here is a website from Pride mobility that will allow you to download a PDF version of the owner's manual for your scooter. Copy this link into your web browser and press enter, then scroll down the page to the Scooter section and you will see the Victory XL-4 listed. Click on the name and save the file to your computer.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
I hope this information is helpful, good luck!
Dec 31, 2010 | Pride New Mobility Victory XL 4 Wheel...
Could you please tell me where i will get forward& reverse throttle for pride victory
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Nov 07, 2010 | Pride New Mobility Victory XL 4 Wheel...
Pride New Mobility Victory XL 4 Wheel Scooter Logo
223 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
