Question about NEC Dterm DTP-2DT-1 Phone
SOURCE: NEC DTerm 80
Try dialing the numbers 725 and then hang up...to turn it off..same thing. Ours works this way at work.
Posted on Apr 18, 2008
SOURCE: NEC Dterm 80 LCD display is defective.
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
Posted on Dec 08, 2008
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Posted on Jan 16, 2009
SOURCE: DTERM SERIES E VOICE MAIL
If its an intergraded VM,, somply dial the main Voicemail number from that phone
Posted on Apr 19, 2009
SOURCE: Voice mail not answering
Press speaker, 43, xxx, speaker. "xxx" is the number of your company's message box, if you know that.
Posted on Oct 20, 2009
Jun 20, 2012 | NEC Dterm Series I Dtr-8d-1 / 780039 Black...
Mar 22, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Jan 04, 2010 | Lands Phones
Apr 14, 2009 | NEC Dterm DTP-2DT-1 Phone
Apr 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Jul 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Jun 13, 2008 | NEC Dterm DTP 32D-1 Corded Phone
Oct 10, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
812 people viewed this question
