Cars & Trucks Logo
Posted on Jun 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Renault scenic radio code lost G002 security
I have lost radio code for my renault scenic. the security No is G002. please help
Travis cook
Level 2:
Champion:
  • Renault Expert 308 Answers
  • Posted on Jul 25, 2014
Travis cook
Renault Expert
Level 2:
Champion:
Answers
308
Questions
0
Helped
229919
Points
373
5 Related Answers
Anonymous
  • 1010 Answers
  • Posted on Jun 18, 2008
SOURCE: cd player comes up with err message
Oh, i had this problem several times... look, the best answer that i can give you is to buy a new one, there's sony's cd-players that are great, me and my father have. now, if you want to stay with this cd player just insert the cd several times until it will play. but again, you better buy a different one.
Anonymous
  • 54 Answers
  • Posted on Jul 17, 2008
SOURCE: renault scenic CD/Radio code!?
you need to ring a renault garage with the chassis num. they will give you a 4 digit code. to enter the code yo must use the control for the radio attached to the steering wheel. if the code for example is 3456 you turn the wheel on the control until the first 0 reaches 3.then click the wheel towards your self to move to the next digit. hen you have all the digits in hold the wheel for approx 3 seconds to enter the code
Anonymous
  • Posted on Apr 13, 2009
SOURCE: my renault scenic radio says code i am unable to
Hi - the way to enable code mode is to turn off the radio - then hold down 2&5 & press the on button - this will bring you into the 0000 code mode.
Regards Paul
Anonymous
  • 13 Answers
  • Posted on Jun 02, 2009
SOURCE: I have a renault scenic 2000, replaced battery need to input the radio code, noticed on this blog that you can push numbers 2, 5 and on button, I did this and my radio came on without me having to inp
You really need the code. The radio will shut down after a period. This is something particular to Renault. It may be a feature that allows the radio to be tested without knowing the code.
Check the handbook if you don't have the code, sometimes people write them inside somewhere.
Anonymous
  • 1986 Answers
  • Posted on Sep 23, 2009
SOURCE: inner door panel removal, renault megane scenic
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
2answers
Renault Scenic radio code
the only way to get that if you have lost the origional vehicle code is to go to a renault dealer with proof of ownership then they can help. or take out the unit and take to someone who can decode it
1helpful
3answers
I need a code for my reanult scenic megane radio t reg 1999 . i had to change the battery and i have lost the code please help
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
32helpful
10answers
My renault scenic radio says code i am unable to enter the digits for the code
Regards Paul
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
john h
Are you a Renault Expert? Answer questions, earn points and help others
