Question about Frigidaire Ovens
Why does the f10 code keep appearing on self cleaning fridgidaire oven? When using oven it starts heating out of control. Tends to happen when oven is being used for longer periods of time.
  • Official Brand Answer
  • 2,267 Answers
Hi John, thank you for your post!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Posted on Jun 04, 2014
  • 1,140 Answers
The thermostat is defective. It is a temperature sensor operated switch. It turns the heating element on and off to regulate the proper temperature in the oven at all times.
Posted on Jun 03, 2014
6ya staff
SOURCE:
After self cleaning my LG LRE 3023ST, the "heating Error F9" code appears and I cannot use any oven feature
You need to replace the door latch mechanism. The switch on the mechanism failed. This usually happens after self-cleaning.
Global Solutions Appliance Repair
https://gsappliancerepairnyc.com/
May 18, 2018 | LG Ovens
What does coded F10 mean on my GE wall oven
This is likely a failed temperature sensor. The sensor is easy to replace but its behind the oven so you have to pull the oven out of the wall which isn't easy. This seems to happen when we use the self cleaning feature, its happened to us twice, havent used self clean since the second time we fixed it and its never happened again.
Nov 20, 2016 | GE Ovens
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Fridgidaire self cleaning range: F1 error code?
You have a control board failure. First thing I would try is to unplug the range for at least 10 min. and then plug back in and see if that works. Hope that helps
May 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not heating up after using self clean oven feature
OK. Not a professional, but I happen to have a lot of experience with this situation. For reference, I have a Whirlpool RBD305PDT11 Double-Oven with a "Self-Clean" feature.
Inevitably, my bride decided that she would "clean" the oven. She set the controls and let it go. At the end of this procedure, I noticed that the electronic control board no longer showed the time or any other lights. So, I checked it out and found that the oven was ENTIRELY non-functional. Virtually nothing would work.
Since this oven is hard-wired, I turned off the fuse and let it sit for few minutes (these things are just computers, so I thought that I would "reboot" the whole thing). This did nothing.
Then, with the help of the internet (thank you, "Fixya"), I found out that this model of Whirlpool oven (and many others of different brand names) seems to have this sort of problem all the time.
It turns out that the physical act of using the "Self-Clean" feature, with its very high heat, blows a few "Thermal Fuses" that are one-use only and cannot be reset. They must be replaced.
First, be sure to turn off the power to the oven BEFORE doing anything. I did this and then took the oven out of the wall enclosure so I could get to the back of the unit. For sake of brevity, I will not go over the procedure to take the oven out of the wall, but those instructions can be found on the internet. Several metal screws hold the sheet metal covering on the top and bottom. Note: This has happened to me twice now (my bride used the "Self Clean" feature without my knowledge) and I have found that the lower Thermal Fuse has NOT blown either time, but the top one has blown both times.
On this unit, the "Oven Shutdown Thermal Fuse" (part number 4451442 costing about $40) is attached with two screws and is located on the upper left section (picture attached below). It is very easy to take the two wire leads off and remove the two screws holding it in place. You can then check this item with a Multimeter to see if the fuse is working. I won't go over the Multimeter instructions, but, you are looking for "Continuity". If you have continuity (electricity will flow), the fuse is good. If you do not have continuity, the fuse is bad.
The first time that this happened (about 5 years ago), the control panel still had lights on and was issuing "error codes" specific to this brand of oven (I don't remember the codes...F1 or something) and the only problem was the fuse as discussed above.
However, the second time that this happened, as I mentioned earlier, the control panel was blank also. So, I had to look for the "Control Panel Thermal Fuse" also. This fuse can be accessed from the FRONT and is behind the control panel. In this unit, that part number is 4451042 and costs about $20. This item is sheathed in clear plastic with a "bullet-looking" thing inside of the plastic. It is very easy to pull this fuse out and check it for continuity to see if it is in working order. Continuity (electricity can flow from one side to the other), and the fuse is good. No continuity, and the fuse is bad. Again, you can check the continuity with a Multimeter. In the second instance of this happening, this fuse was bad also (that is why the control panel had no lights or error codes or anything).
Once I replaced these fuses, the control panel came back, the oven would then respond and worked just fine. If I was to guess, I would say that the cabinet that the oven is installed into is too tight of a space and the temperature just gets way too hot and the fuses blow. This is just a thought, but maybe a fan set to blow at the unit when attempting the cleaning process would help keep the unit somewhat cooler on the outside. But then, at $60 to fix and all of the hassle involved, I am NOT willing try this just to see if it helps!
Just to get in a rant....How a company can sell a unit with a feature of "Self Cleaning" that, when used exactly per the instructions, will render the unit completely useless is WAY beyond me. oven-not-heating-up-after-using-self-m2kgk0sj4irmtvrbwm3x5vdv-1-1.jpg oven-not-heating-up-after-using-self-m2kgk0sj4irmtvrbwm3x5vdv-1-3.jpg
Mar 31, 2011 | Whirlpool GBS277PD Electric Single Oven
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 23, 2010 | Thermador Ovens
I have a Fridgidaire Galaxy Oven,can you tell me how do I set the self cleaning oven?
Greetings,
I can't locate your model number, but, if you have the one with an electronic control..just put it to clean and maybe set the clean time and it should start the cycle and lock the door by itself and start cleaning.
if it has knobs for selector, and a knob for oven thremostat and a clock with two or three knobs.
put the selector on clean, put the thermostat on clean and then go to clock and set the stop time three hours past the time thats showing on your clock(providing its keeping time) and lock your oven door and it should start.....Bruce Denton
Dec 13, 2010 | Frigidaire FFEW2725LB Oven
F10 error has me baffled
F10 error is: Runaway Temperature
what you can do:
1. (F10 only) Check *RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
*RTD SCALE
Temperature (�F) Resistance (ohms) 32 � 1.9 1000 � 4.0 75 � 2.5 1091 � 5.3 250 � 4.4 1453 � 8.9 350 � 5.4 1654 � 10.8 450 � 6.9 1852 � 13.5 550 � 8.2 2047 � 15.8 650 � 9.6 2237 � 18.5 900 � 13.6 2697 � 24.4
hope the chart dont get jumpled if it does go to
http://www.applianceaid.com/faultcodes3.html
please rate this and check fixya if it has answered what the f10 error is. for safety reasons I wouldn't use it if it tends to keep getting way over heated until you have replaced what I said above or have had it serviced.
Nov 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
73 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
