Maytag MSD2454G Side by Side Refrigerator Logo
H
Hendy Spence Posted on Jun 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker not working and top of freezer not always frozen
Because top of freezer not always frozen we turned it all off for 24 hours. At that time the ice maker was working. Put the ice maker back and it didn't work. Took it out and put it back and it worked. By mistake it was taken out again and now can't make it work.
william rodriguez
Level 3:
  • Master 958 Answers
  • Posted on Jun 04, 2014
william rodriguez
Master
Level 3:
Answers
958
Questions
Helped
169566
Points
2511
When you put it back in for the last time does it do anything? Does it make any noise or movement. If it does then check to see if water is coming into the ice maker. if it is not then you may have a water inlet problem
Testimonial: "Water does come through. Could it be the fan (if there is one) in the freezer?"
5 Related Answers
Anonymous
  • Posted on Aug 03, 2008
SOURCE: Maytag ice maker
I have maytag msd2756deq the water in icemaker is not comming. I replaced the dual water valve too.
Mani
Michael O'Donnell
  • 3 Answers
  • Posted on Nov 22, 2008
SOURCE: Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Henry Russ
  • 31 Answers
  • Posted on Feb 07, 2009
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Anonymous
  • Posted on Apr 12, 2009
SOURCE: Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Anonymous
  • 103 Answers
  • Posted on Jun 01, 2009
SOURCE: my ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
WHY DOES MY ICE MAKER ONLY MAKES ICE SOMETIME
Are the cubes normal - the right size, not hollow? Once frozen and the harvest cycle begins, does it take longer than a couple minutes for the cubes to drop? After the ice drops does it fill with water each time?
If everything checks OK the last thing is very important. The rate at which an ice maker produces cubes depends on the temperature of the freezer - the colder it is the quicker the cycle. Try nudging the controls up a bit and wait 24 hours.
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
Ice maker is not producing ice. the water dispenser on the door is working just fine. turned off the freezer to see if the line to the icemaker was frozen, still no luck. ideas??
Did you leave the freezer off for a couple days then turn it back on? if you did that, then waited 24 hours it sounds like you did a good job on checking to see if the line was frozen. Then i'm really starting to suspect the ice maker itself is either not cycling because its bad or maybe it is and the water valve is not producing water to the ice maker. Those are the two directions id take it at that point.
Ice maker will not fill with water
Water might be frozen in the tube that fills the ice tray. Check the tube and if it's frozen shut, use a hair dryer to heat it until the ice piece melts out. Your icemaker should work after the fridge has been closed for 24 hours to cool back down.
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
1helpful
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
I have the automatic frozen yogurt-ice cream & sorbet maker ICE-20 series made bby CUISINART. The first few times the icecream came out perfect & great. I made ice cream yesterday and it was soupy. I put...
I would actually let the freezer bowl thaw out on a level surface. Then place perfectly level back in the freezer for 24 hours. Should work again. Enjoy!
-Tha Mp3 Doctor
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
2answers
If you press and hold the button on the ice maker for seconds it will go into test mode and do a complete cycle. Try this and it should correct the problem. If you think the arm is frozen, you could use a hair dryer on it for a couple of minutes then do the test.
Sgt 48
2helpful
Attaching icecream maker
KitchenAid Ice Cream Maker Attachment:transp.gif
Convert any KitchenAid stand mixer into an ice cream maker with this handy attachment, and you can make a homemade treat that's fresh and pure. Store the bowl in the freezer, follow directions and you'll soon be making up to two quarts of your favorite frozen dessert. The ice cream maker is designed to fit all KitchenAid household stand mixers.
Includes:
  • Double-walled Bowl
  • Churning Blades
  • Basic Recipes
    Instructions: The freezer bowl must be frozen for 18-24 hours prior to first use. Before each use, bowl must be completely frozen. Cycle time: 30-min. for soft-serve ice cream. For firmer consistency put in freezer for 1-2 additional hours.
  • Not finding what you are looking for?
    Top Maytag Refrigerators Experts
    vince
    Johnny 1000
    Jesse Walters
    Jesse Walters
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
