Question about Drills
Show wire diagram for AL 1115 CV CHARGER
Wire diagram for AL 1115 CV charger
Posted by louis on
Brad Bancroft
  • 61 Answers
WeIl I dont know the language but the rest makes sence, show wire diagram for AL 1115 CV CHARGER - 0749d6a5-1dbe-4a91-85d2-5ce491855854.jpg
Posted on Jun 05, 2014
  • nikolaos papaioannou
    nikolaos papaioannou Aug 08, 2018
    hello from greece its blow (R1 its thermistor ntc 10d-7)?
What is the wiring diagram for the switch on a schumacher model se-150-15 battery charger?
I would like to see a wire diagram of my battery charger Schumacher model #se-5212a-CA
Mar 29, 2015 | Schumacher & Fast Charge Starter Charger
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
I was cleaning the transfer charger as detailed in troubleshooting the unit. I broke a wire that was attached from side to side
The tungsten wire must be replaced. I would take it to a SHARP / independent dealer and pay them to replace it.
Unfortunately this is specialized wire and is not generally available to end users.
Feb 07, 2011 | Sharp AL-1641CS Laser Digital Copier
I have a JET Mobility Model 2904JT-24 Battery Charger that I would like to use to charge a 24-V project I'm working on. It's from a Pride Jet 2 HD. Trouble is, I only have the charger (no wheelchair) and...
Blue Positive Brown negative, Yellow with green stripe is additional ground. many people are trying to use the 2904JT charger for a 24 volt charger for other things. I am using mine on an e bike that has 4 12 volt batteries. I charge them 2 at a time and it works well. It only shows voltage when the batteries are partially charged. Some kind of safety feature to keep you from charging a shorted battery. No schematics available, I took my chances and verified the Blue wire is positive. lol Good luck with you project or re wire. : )
Jan 24, 2011 | Pride New Mobility Victory XL 4 Wheel...
Looking for wirring diagram for schmacher SE-1275A battery charger. Wires got pulled out of component need to know where white wire & black wire goes.
yay I emailed schumacher asking about this and they got bak to me within 12 hours or so with EXACTLY what I needed
I looked a long, long time without finding anything like this online, and many different people asking the same questions
so please save this picture for your records, and if you have a minute, go post it on an unanswered schumacher battery charger wiring diagram question
Jan 18, 2011 | Schumacher DSR ProSeries Battery Charger -...
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Ez Go 28115-G01 battery charger does not work.
I have an EZGO powerwise 36V charger, model 28115-GO3 that was installed onboard a cart. I want to use this charger for another cart, but the charger has 3 wires out. Why 3 wires? One is +, the other -. what do I do with the third wire? The wires are red, black and yellow; two odf the wires are 10-12 gauge, the other is around 16 gauge.
Mar 26, 2009 | Electronics - Others
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
http://tech.groups.yahoo.com/group/power-assist/files/EV-Warrior/
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
rick
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Hp Laptop Won't Charge
SHOULD CUT THE WIRE AND SPLICE THEM TOGETHER
UNLESS THE BENT END IS AL THE ENT OF A POWER CHARGER, YOU COULD STRIP THE WIRE, TENT THEN ENDS AND SOLDER THEM TOGETHER
Feb 17, 2009 | HP Compaq Presario C304NR Notebook
Drills Logo
6,111 people viewed this question
Top Drills Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Drill Expert? Answer questions, earn points and help others
