Question about Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
What is error code 3 in the usb mode for the alpine cde-143bt CD?
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
Anonymous
SOURCE: Connecting High Speed IPOD Cable to Alpin CDE-9874
Best Buy solved my problem.
Posted on Oct 02, 2008
Anonymous
  • 3 Answers
SOURCE: Installing Alpine CDE-9852 CD Reciever In A Ford Mercury Sable LS
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
Posted on Nov 08, 2008
Anonymous
  • 74 Answers
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Posted on Nov 28, 2008
Anonymous
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
Why won't it turn on?
You have bent one of the small tines that engages the detachable faceplate with the unit itself most likely. You will need to get a magnifying glass and a fine jewelers screwdriver to straighten any bent tine so it connects properly.
Jul 27, 2015 | Alpine CDE-143BT Advanced Bluetooth CD...
How do i get code for bluetooth
First make sure that Bluetooth is on on the CDE-143BT. Press and hold Audio/Setup (below and to the right side of the rotary encoder dial until you enter the Setup mode. Use the rotary dial to get to Bluetooth. Press the Search/Enter button (the center of the rotary dial). Then use the rotary encoder to go through the Bluetooth Settings menu. Press Search/Enter to toggle the current value. After Bluetooth is on, go to Visi M setting and make sure that it is on. Now, you need to go to the Bluetooth settings area of your cell phone when it is within range of the receiver. Tell it to pair with the receiver. Then when it asks for the code enter "0000". This code is hard encoded into the unit. See page 23 of the manual for the CDE-143BT for the code. The manual is available here: http://vault.alpine-usa.com/products/documents/OM_UTE-42BT_CDE-SXM145BT_CDE-143BT_EN.pdf . Surrounding pages show setting the other Bluetooth settings.
Note: the receiver will be acting like a Bluetooth headset. That's why you need to enter the receiver's PIN on the phone.
I hope this helps.
Oct 10, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
Alpine installation
It might wear the cd drive by putting too much weight on it.
Jul 21, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
How do i set the time on my alpine cde 9841?
Setting Time
displayed.
only) or press 4 and 3 (CDE-9841 only) to adjust
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
Or you can ge tthe manual on the link below.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
Jun 17, 2011 | Alpine CDE-9841 CD Player
Hello desoren,
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Alpine CDE-9843
Setting Time
displayed.
only) or press
only) or press
Apr 26, 2008 | Alpine CDE-9843 CD Player
Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
