BENQ - HDMI - 24 " Computor Monitor
When I turned on computer,BENQ Screen showed "HDMI-No Signal" Everything was alright previously and have not had any problems in the past.
Posted by adrian pryzibilla on
Gerald Priest
  • 28 Answers
Check your cables. It is possible one has become disconnected or damaged (from being crushed or twisted). Check with a different cable.
Posted on Jun 03, 2014
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
My Benq monitor was working, then it suddenly went black and said Hdmi no signal. After a few hours, it started again fine, but when I tried to play a game, after a minute or so it went black and star
Check the signal cable connected in between monitor and system for firmness. Re-seat at both end once and check. If it does not help you, contact any service technician. Gopakumar Gopalan Google
Can't connect Panasonic Viera TV to PC with HDMI
Check your owners manual. Some TV's will not except PC resolutions.
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
I've PS3 and BENQ 24'' (HDMI) why showing NONPRESET MODE? I can't see anything it just black. Who can help me with this please anyone
You need to lower your PS3 video resolution to the native resolution of this monitor, it is too high right now taht is why your are getting the message on the screen.
Start PS3 with lower resolution and go upfrom there.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
1helpful
"out of range" when connecting ps3 -> benq t221w
It display out off range because the PS3 is feeding the monitor with higher resolution that the monitor cannot suppoert, try setting the PS3 to the lowest resolution first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
3helpful
2answers
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
3helpful
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Computers & Internet Logo
Ekse
