Computers & Internet Logo
How to connect new flat screen tv with hdmi cable to an olin ross sound system 6050 home theater 1000 watts
Posted by Roy Tevay on
Joel Friedenberg
  • 1,114 Answers
Evidently this system is a speaker system that hooks up to 5.1 home theater receiver. I've included a few quote on how to hook up the 6050 system:
" Measure and cut wires running from the speakers to the receivers"
Read more: http://www.ehow.com/how_10058195_hook-up-olin-ross-or6050.html#ixzz33bqoGyyY
"Run the wires from all speakers and the subwoofer to the back of the receiver".. The key is to have a home theater receiver, then you can hook up the TV to the receiver.
Posted on Jun 03, 2014
How to connect flat screen with hdmi cable to an olin ross sound system 6050 home theatere 1000 watts that only has speaker wire connections
Look to see if there is an audio out with RCA connectors on the TV. You can't recover audio from the HDMI cable directly. It's impossible because the audio has to be taken from the HDMI signal electronically.
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Hi .. need to connect my tv audio through my pioneer 5.1 home theater.I was using normal video audio cable ...shall i use component cable???pls advice
"Component" cable refers to the 3-wire hi-def video connection. It's irrelevant to audio.
Assuming you get all your TV programming through a cable box...
The TV wouldn't actually be a source of audio.
I would advise you to route the Cable Box's BEST DIGITAL audio directly to the Pioneer model number ????? (which would be helpful to know for this conversation).
Run the cable box's normal analog audio to the TV so you can watch it without the Pioneer turned on.
And route the best Cable Video (HDMI, Component?) directly to the TV. Unnecessary paths through the receiver can degrade the signal.
1helpful
No surrond sound
TV's are not sources of multichannel audio. The best you'll get is stereo analog. Get the best TV-related audio from the same source the TV gets it - in this case the Cable Box.
Hooking samsung htz310 into insignia 52 inch flat screen
From what i learnt you learnt to connect tv to system with hdmi and a  optical lead..
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Marvin
Marvin
