Question about Lexar 8GB JumpDrive TwistTurn - USB Flash Drive - Hi-Speed USB - Blue
How do I get my document back from Lexar 8GB JumpDrive TwistTurn - USB Flash Drive
Hi... In sending a document to a file, I chose the wrong document. Where did the right document go? Can I get it back? I was using a Lexar flash drive. Sara
Posted by Sara on
funkotronic
    Problem Solver:
  • 9 Answers
Hi Sarah... We will need to know a few more specifics before any information can be given to you. What program where you in, and what type of document were you trying to save. If you were in Microsoft Word, you can go up to the "file" menu, and look for "recent items". At that point, you would be able to open the document that you were working on, and then save it to your location of choice. What you might find simpler in the future, is to simply save documents to your desktop, and then drag them to the flash drive directly from there. At that point, you will have the document both on your desktop and the flash drive, and you can then take the documents it is still on your desktop, and move it into your documents folder...
Posted on Jun 21, 2014
3 Related Answers
Anonymous
  • 86 Answers
SOURCE: lexar flash drive
First, download and try to extract all the files from your drive with this tool:
http://www.lexar.com/drivers/files/ImageRescue_2.0-u(b16).zip
Second, at the moment that you are sure that you have all your files backed up, if windows recognizes the drive, try to right click on it and format
Posted on May 06, 2008
ericb777
  • 24 Answers
SOURCE: How to recover data from a seemingly dead/non-functional USB flash drive
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
Posted on Jun 25, 2009
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: Lexar JumpDrive S70 - USB Flash Drive - 8 GB disconnect
this could a problem with an unstable driver you might have to unistall the driver restart your computer then reinstall the driver
if you motherboard came with a disk the drivers could be on it
otherwise you might need to download them
or a bad dusty or loose usb lead connection
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Posted on Aug 14, 2012
Where is the checkbox in polaris office
When you are in the document, in the upper right hand courner you will have three stacked dots (Fig #1.) Touching it will give you a drop down menu, (Fig #2.) Choose Send Document. Chose how you want to send it (Fig #3.) Fin.
08973e71-7b12-43ac-b795-ded12fb9a079.png 176079fd-26e8-4197-8c19-68dcb7b228da.png daf57952-973e-495f-8f61-f9b2e10bf6b8.png
Oct 07, 2014 | Tablets & eReaders
Lexar 16GB S73 appears as Innostor NAND Flash USB Device
can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Dec 09, 2013 | Lexar Media Jumpdrive S73 - Usb Flash...
Lexar usb 2gb
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Jul 04, 2012 | Lexar 2GB Multi-Color USB Flash Drive Kit...
Lookinf for instructions on how to e mail pictures from my M340 easy share camera to friends.
You first download the photos from your memory card to your computer and usually to your My Documents-My pictures.Then connect to the internet on your email account,lets say yahoo for example.Then go to compose a new message and right down the under the "Subject"box you will see Attach files box there,click it and you will be shown at least four rectangular boxes numbered file 1:choose file.Click it and you will be given a dialog box on where to get he files you want attached.Go to "My documents-My pictures then click the photo you chose and click [open] on the right hand option box.The file you chose will now appear on the File 1 rectangle box. Do the same for the other files if you want to add more pictures.Then of course send it.Sending it may take time,so be patient.If successful it will say "sent".If not some of your file are too large.Reduce the megapixels to a max.of 3.00mpxls. in your camera.Good luck.
Oct 30, 2010 | Kodak EasyShare C340 Digital Camera
I cannot print my documents even if there is Microsoft Office Document Imaging?
hi,
open Microsoft Office Document Imaging then opened the Tools menu, then
Options. In the Options window, select the "Other" tab and clicked on the "Reset" button under Default Program.
Then, close Microsoft Office Document Imaging and open windows explorer, navigated to an "*.MDI" file, right clicked it and chose "open with" "choose a program" then browse to the Microsoft Office Document Imaging executable found in the Office folder (don't remember the exact location) and select that executable to open *.MDI files and check the box "always use this program to open this file type".
Now, finally, the "File" menu in Microsoft Office Document Imaging will work
May 12, 2009 | Microsoft Office Professional 2007 Full...
Flash drive repair
Eric Beaudoin
[email protected]
Mar 24, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
How to save my documents to lexar 2gb jumpdrive
You can simply drag the My Documents to the drive, that will make a copy. But you could also use the backup function of Windows (simply type 'backup ' in the Windows help and follow instructions).
Jules
Mar 02, 2009 | Lexar JumpDrive Classic Portable USB Data...
Eric Beaudoin
[email protected]
May 18, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Lexar flash drive
Apr 14, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Lexar 8GB JumpDrive TwistTurn - USB Flash Drive - Hi-Speed USB - Blue Logo
70 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Harrie
john smith
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
