Question about Jet AFS-1000B Air Purifier
Remote will turn the air filter on but will not turn it off. Have two in my shop with the same problem
Changed out batteries etc, but both units respond the exact same way. The unit turns on with remote but it will not respond to changing time, speeds or turn off with remote
Posted by Donna Cunning on
Mike
    New Friend:
I had similar issues and by replacing the 2200 micro (Mu) Farad, 10 Volt capacitor on the PCB, all of my issues ceased.
Below is a link with information supplied by "fixya" that explains the procedure/details.
Hopefully this will solve your current issues.
Good luck,
Mike
http://potlash.org/feast/2010/11/20/repairing-a-jet-afs-1000b/
PS Linda Haus of "Rockler" Technical Support was kind enough to supply me with this link.
Posted on Jun 05, 2014
Stephen Schroeder
    New Friend:
$1.26 fix to JDS and Jet air filtration remote problems is here:
https://youtu.be/lVL5NOKgorY
Posted on May 25, 2019
Boris konovich
    New Friend:
That link above is wrong, this is the correct one:
http://potlach.org/feast/2010/11/20/repairing-a-jet-afs-1000b/
Posted on Dec 03, 2014
Changed filter and pre filter both lights continue to blink, not resetting
Hello, this is Ava with Think Crucial.
Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance.
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jun 18, 2016 | Honeywell Air Purifiers
How to change the flter
Turn off the unit and unplug it. Turn the air purifier on it's side and unscrew the locking mechanism (turn counter-clockwise) on the base of the unit. Remove the base assembly from the unit. Remove the filter assembly and find the seam of the pre-filter. Carefully separate the fastener and then remove the pre-filter from the HEPA filter.
Discard the filter(s) being replaced. Then remove the new filter from the packaging and discard the packaging and plastic. Carefully wrap the pre-filter around the HEPA filter so that the ends meet. Fasten the ends together with the fastener.
Place the filter assembly in the air purifier and reattach the base. Then tighten the locking mechanism. Turn the unit right side up, plug it in and turn it on.
You can find a pdf of the manual here: http://www.honeywellpurifiers.com/product/0-90271-50150-4.html .
I hope this helps.
Oct 03, 2010 | Honeywell 50150 Air Purifier
My filters turn black after about a week
I am also experiencing this problem, as well as 2 other people that I found on google, so I am inclined to think tha 3M has changed something in their manufacturing process, I think it very odd that this problem is manifesting itself at this time in different locations.
I have been using this product for sometime, and the problem of filters turning very dark did not exist when I started using this product
Jul 02, 2009 | 3M Filtrete Ultra Allergen Air Filter...
It appears to have been on fire,surronding walls & unit covered i
hmmmm... maybe it was on fire... Barring that,
One thing to be aware of is how these things work: they don't actually filter the air. Rather, they electrically charge dust/dirt/etc. particles in the air as they pass through. This new charge makes them attracted to walls, floors, objects, etc. So rather than straining or filtering dust from the air (like a more traditional air filter), they make dust more likely to stick to walls, surfaces, etc. so that you can then wipe them up.
If there is something in the room that is manufacturing air pollutants, it could cause the problem you're having. The most likely culprit is anything that makes smoke. For example: smoking (duh), or burning CANDLES (especially scented candles) or INCENSE.
Jun 22, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Red light on...
the unit probably needs to be reset. cause what's happening is that it's not recognizing that the filters are clean. there should be a tiny pin hole at the top of the unit. when the unit is on you need to put a small needle in there and hold for about 5 seconds and the unit should reset. if that doesn't work please please let me know and i will see what else we can do.
Mar 12, 2009 | Holmes Products HAP725-U Air Purifier
My remote control stopped working
i do apologize for the inconvenience the only thing that i can suggest is the that whole unit will need to be reset. so the machine can connect again with the remote. also make sure that batteries are fully charged. If that doesn't work please let me know.
Oct 19, 2007 | Bionaire BAP1500-U Air Purifier
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Can't turn it on -- need manual
you have to plug the unit into the wall directly and not to a power strip or UPS. Then just choose the speed for continuous filtering.
Aug 31, 2007 | Honeywell Enviracaire 17352 Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Can the unit be mounted in a window?
there is no reason why not if the outside part is properly weatherproofed and screened to stop insect etc ingress - easier may be to duct the unit to a hole in a window - use at least 125mm/5inch ducting and dont make it too long. It is not recommended to run the unit in this way, however, as you will almost certainly find that the filters etc will block very quickly due to many more airborne particles(especially living ones) in outside air (depending on your situation) and the fact that inside a room with the unit running you have a relatively closed system that will steadily get cleaner as you use the unit. best way to test this would be to run the unit normally but outside for a while to see if it functions ok. Hope this helps - i cant see that you would gain anything from running the unit in a window apart from higher filter replacement costs :)
Oct 09, 2006 | 3M OAC100 Air Purifier
Jet AFS-1000B Air Purifier Logo
657 people viewed this question
Top Jet Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Jet Air Purifier Expert? Answer questions, earn points and help others
