Hi
not sure if that model has an electronic or manual steam valve - if electronic, it may be leaking slightly. If manual, its either not being turned right off or it also has a leak which allows water to get past it... eg - a leaking tap.
Ring your Saeco dealer, explain whats going on - should noit be too much to have fixed.
Cheers
Mike
SOURCE: Saeco Gran Crema Espresso does not pump water
The machine needs to be primes.
Please trie and release hot water though the steam nossle.
Do like this
Open the steamer and then trie and make a cup of coffe. this will make the hot water come out thought the steamer instead of the coffe outlet.
Why you should do this is becuse the machine has it alot more easier to prime it self though the steamer then the coffe outlet.
SOURCE: Steam not frothing properly (very weak output)
It can be the electric magnet valve that has to be replaced.
SOURCE: EAM3500S will not froth milk ?
First, check to see if it will pump out steam without a ton of water. If it doesn't, don't use it.
Now, skim milk is terrible for it, the bubbles are too dry and
flavorless. Use 2% milk or half-and-half. It should be cold (very
cold). I put mine in the freezer in a steel frothing container for 5-10
minutes before use. Just barely submerge the wand (about .25") and turn
on the pressure. It should sound like tearing paper (not like blowing
bubbles through a straw). Do this until volume increases to around
double (if you have a frothing thermometer, it should be around 100
degrees F). Now submerge the wand farther and tilt the cup to create
swirling (this is called stretching & sweetens the milk). This
should be done until the temperature is around 140-160 degrees F. Done.
If your machine is no good for steam, there's another way: Put milk
into a steel cooking pot (I use a saucier for large groups) and put it
in the freezer. When very cold (ice forming) put on stove. Whisk
briskly while heating up on medium-high. It will create fine foam &
stretch the milk at the same time. The bubbles will start big, but
become finer as time goes by. I test by stocking my finger in &
going until it feels nearly scalding & remove from heat. Just use a
ladle for he milk & a spoon for the foam.
SOURCE: Steam stops after few seconds and water and temp lights blink
Check the 2 limit sensors on the boiler.
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
