Question about RCA F32650 32" TV
How to do factory reset on rca tv f32650 - RCA F32650 32" TV
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Proper grounding point for RCA F32650 TV
Leave set unplugged for a few hours = HV gone or discharge to CRT ground strap........................
Note: Part list.....257805 or ASTI 2078 xformer and
237470 horiz output xistor ( Do not use generic)
transistor must be first quality, no seconds ! !
Posted on Dec 11, 2007
Anonymous
SOURCE: RCA F32650 TV changes channels by itself
Problem is common to RCA models. The issue is bad solder joints in the tuner area. Resolder the entire tuner section of the board and the problem will be resolved. No parts are necessary.
Posted on Aug 29, 2008
Anonymous
SOURCE: RCA TV F32650 32in
The colour is set through the hidden service menu. This web page has detailed explanations of how to access and use the service feature http://www.artofhacking.com/files/TVMODES.TXT
Paul
  • 224 Answers
SOURCE: Rca Television
I think that both of you have faults on the power supply of the tv. If you are able to check this yourself start with the diodes and resistors if not then find a competant technician. Hope this helps.
Posted on Oct 03, 2008
Anonymous
  • 26 Answers
SOURCE: RCA F32650 32" TV Problem:
The flyback is a a block with some wires coming from it. One of the wire is a big red wire that goes to the picture tube. The FBT is usually on the right rear of the circuit board.
Please be careful when working around the FBT as there are extremely high voltages present - in excess of 25K.
I would suggest you take it to a service shop as when the FBT goes, other parts are usually gone too.
Posted on Nov 17, 2008
How to reset rca tv
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 01, 2014 | RCA F32650 32" TV
Factory reset
The TV can be restored to factory settings for different functions. There may not be a single factory setting. Refer to manual at this site
http://www.retrevo.com/support/RCA-F32650-TVs-manual/id/402ag411/t/2/
It will depend on what function you want to reset to factory setting. For example Parental lock password etc.
Jun 02, 2014 | RCA F32650 32" TV
My RCA F32650 32" TV keeps turning on and off. I
hi there! i hope this will help u find the solutiuons:
1. replace the power transistor at the horizontal section of your tv by desoldering . and buy with the same value, the store assistant in your area will do help you replacing the defective part of your tv. Thank You.
Feb 06, 2011 | RCA F32650 32" TV
RCA F32650 Bad Circuit Board
try pts electronics, just go to search engine and type board number and it will tell where yoiu can buy it . at least 250.00
though.
bc
Feb 26, 2009 | RCA F32650 32" TV
No channel line up in guide plus
Tune your TV to a Public Broadcasting Station before turning it off for the night. You should receive your line-up.
Oct 26, 2008 | RCA F32650 32" TV
Aug 27, 2008 | RCA F32650 32" TV
RCA TV F32650 32in
May 16, 2008 | RCA F32650 32" TV
Bad RCA 32 Tube TV
Bad IHVT ( HV transformer ) part # 257805 or ASTI 2078
......................................................T.
Dec 11, 2007 | RCA F32650 32" TV
Nov 25, 2007 | RCA F32650 32" TV
RCA F32650 32" TV Logo
80 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
