Question about RCA P52926 52" Rear Projection Television
Fuse for RCA model p52940 - RCA P52926 52" Rear Projection Television
1 Related Answer
tlm931
T.l. Moore
  • 273 Answers
SOURCE: reset button on 52 in rca rear p52940 home theater
this set does not have a reset button if there is a system lock out unpluging it for 3 or 4 mins will reset when pluged back in
if that does not help try trouble shooting the set ck the ac fuse and so on
Posted on Oct 24, 2009
How can I change my bulb in my tv
You just need to remove the back of the television to get to this. Unplug the TV first and hold the power button for about 2 minutes to drain the charge. The capacitors will knock you over if you accidentally touch them charged up and they will hold onto it. After that, locate the bulb and replace. You may actually have a three gun set up which would mean either one to three are out.
Jun 01, 2014 | RCA P52940 52" Rear Projection Television
We have no picture, but sound, and the picture is working on menu, and setup. hooked to spare tv and picture works.
the input is bad try another input. if same problem input board is bad replace it. could be time to try a new set.
Dec 26, 2010 | RCA P52940 52" Rear Projection Television
Iam getting duplicate picture
replace the convergence OC its a STK730-130 you need only one you can get one at www.tvrepairworld.com
Nov 20, 2009 | RCA P52940 52" Rear Projection Television
Reset button on 52 in rca rear p52940 home theater projection television located
Oct 24, 2009 | RCA P52940 52" Rear Projection Television
Projection RCA P52940
sounds like it is most likely the convergence power supply board, if it were just one color It would most likely be the convergence board itself
May 27, 2008 | RCA P52940 52" Rear Projection Television
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
RCA P52940 Television
The P52940 uses the CTC195 series main chassis. The most common reason for the set not to start up is a shorted flyback (high voltage) transformer. The set actually does try to start, but the computer immediately detects the extra current drawn by the shorted flyback and instantly shuts the set back off. The chassis should be checked and the flyback replaced by a qualified tech familiar with RCA projection TV's.
Aug 12, 2007 | RCA P52940 52" Rear Projection Television
Rca 52 inch rear projection
This is a problem common with some RCA/GE TV's. The fix in the past was to install a capacitor between ground and pin 15 of the microprocessor which keeps a data signal riding on the video stream from muting the sound on most stations. By installing this capacitor, you would be disabling the closed caption feature so that feature would no longer work. An authorized RCA TV repair shop may be able to give you more information.
Apr 12, 2007 | RCA P52940 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
