1.1 (cubic feet) = 1 900.8 cubic inches - that is length x depth x height... could be 1 inch by 1 inch by 1900 inches high (unlikely)... but that would still be 1.1 cu ft... or 12 inches by 12 inches by 13.2 inches... and so on
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Since there are 12 inches in a foot, there are 12x12x12 or 1728 cubic inches in a cubic foot.
Dividing 1404.4921 by 1728 gives about 0.8128 cubic feet.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet. For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft. Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height With the dimensions you give Volume=12.5in X 37in X 20in Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot. L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728. your answer is 5.35 cubic feet.
12 inches in 1 foot 144 square inches in 1 square foot 1728 cubic inches in 1 cubic foot
to convert you put the unit you want to keep on top of the dividend. to conver to to feet ( randomly selecting 100 inches) Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet 12inches
or cubic inches to cubic feet 4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft) 1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit. it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in) 1cu ft
