Question about Sony KV-32S26 32" TV
How to repari sony trinitron kv-1370R power switch won't work, remote won't turn it on
Tv has been working fine but power switch on the tv has not functioned for a long time so have been using remote to turn it on. After turning turing off the circuit breaker the tv is plugged into the tv will not come on with the remote. What can be done to repair this problem?
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Sony Trinitron KV-27S46
There is a problem in the sweep section of the set. The Horizontal sweep power supply most likly. there is nothing a layman can do as it will involve troubleshooting the solid state circuit. please find a trainded tech to assist you in this repair.
Posted on Sep 22, 2006
Anonymous
  • 3 Answers
SOURCE: Sony FD Trinitron WEGA KV 32FS120
This model does not have a G board. I will post when I have this solved.
Posted on Sep 23, 2007
Anonymous
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Posted on Dec 12, 2008
Anonymous
SOURCE: PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Posted on Mar 16, 2009
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My remote worked fine, but suddenly won't work at all. TV is older Sony Wega 24" Trinitron (KV-24FS100). The satellite remote will change the channels, cause it's using the box, but it won't control...
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
Nov 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony TV not turning on
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron Tv
Dear sammy5,
Stop by any TV repair shop in your area, and ask to borrow a used original Sony remote, they may require a small deposit; access the menu, perform your set up, then return it. Or you could buy a universal Sony remote from Walmart that should work just fine, for about. $7.00.
Hope this helps.
Richard
Oct 31, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32S26 32" TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
