Question about Motorola Walkie Talkie 2-Way Radio
I got 2 Motorola TLKR-T3, I haven't used them a few months, now one is transmiting but not reciving, and the other one is reciving but not transmiting. They only work both on monitor mode, wich has a really loud and annoyng static sound.
Posted by Balog Antonio on
Motorola Mobility
  • Official Brand Answer
  • 3,100 Answers
Balog-
We recommend you contact Motorola Solutions Support: portal motorolasolutions com
Mark
Motorola Mobility Support
Posted on Aug 28, 2014
5 Related Answers
Anonymous
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
They worked fine the first time we tried them out. Then they were put away for several weeks, and when they've been switched on, one now doesn't send. I checked this by the other putting in scan mode but it doesn't stop scanning at the channel it is assumed to send with. I tried all the channels for sending but neither one is detected. The other way around, so the first one in scanning mode, the 2nd in send mode, works fine (the scanning stops at the channel of the sending one, as expected).
So my conclusion is, that one doesn't send.
I interchanged the (fresh) batteries, but this doesn;t change.
So what could be the problem?
Posted on Jul 30, 2010
Anonymous
  • 27 Answers
SOURCE: motorola tlkr t3 both units power up ok they are
Your PL or DPL is not set correctly.
Check your owners manual, you can set this with the user buttons on the radio.
Press and hold the PTT button while turning the radio on. this will put the radio in the programing mode.
Be careful, if you do not know how to set the PL DPL or frequency you could make the problem worse.
Posted on Aug 24, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: I recently bought a Motorola Walkie-Talkie TLKR-T3
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Posted on Jan 11, 2010
Anonymous
SOURCE: TLK3 T3 Motorola permanent static noise
Mij TLKR T3 has he same problem. This solution does not work for me.
Posted on Jul 23, 2010
eradiostore
eradiostore
  • 1658 Answers
SOURCE: My TLKR-T3 does not work. One
Check your programming. The frequency and code must be identical on the two radios. Here is a link to the user guide http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
The description you give is indiciative of the code being set differently between the two radios. For basic operation set the code to off (zero).
Best regards.
Posted on Nov 05, 2010
I have 2 Motorola TLKR-T3, I haven't used them for a few months but now I replaced the old batteries with new ones and one is not reciving but transmitting, and the other one is transmitting but not...
Try to google or contact maker for
reprograming codes or buttons to hold down
or a web site to download it from an hook them
to computer an load. Sounds like a program
prob
Jun 01, 2014 | Motorola TLKR T5 Two Way Radio
Motorola TLKR T3 one way not working but Monitor works...
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Nov 20, 2012 | Motorola Radio Communications
My Motorola TLKR-T3 won't work properly. Both transmitters-receivers work only in monitor mode. I have downloaded the manual and I made with high accuracy the step to set the devices properly, but nothing...
i had them for 5 years.
and they were just great.
in 6 months the one after the other did the same thing.
motorola is trying to tell us that we have to buy a new pair.
they sould know that i will not buy motorola again
Apr 01, 2011 | Motorola TLKR T5 Two Way Radio
My TLKR-T3 does not work. One of them is possible only receive menssagem ( Receive the transmission ). So it is not possible to transmit zero messanger. Seems that the microphone is not...
Best regards.
Nov 04, 2010 | Motorola TLKR T5 Two Way Radio
The "MONITOR" is probably stuck on. You can go to
http://www.mods.dk/manual.php?brand=motorola and login (its free) and download the manual and look for how to turn off the "MONITOR" function.
Nov 02, 2009 | Motorola TLKR T5 Two Way Radio
Motorola TLKR T3 communication problem
svp dite moi comment les refaire marcher car il y en a un qui recoit tout et l'autre rien du tou svp aider moi
Oct 04, 2009 | Motorola Talkabout T5720 (7 Channels)...
Motorola tlkr t3 both units power up ok they are
Aug 03, 2009 | Motorola Talkabout T5720 (7 Channels)...
I have a TLKR-T3 and a T5720 radios. can they communicate? Thanks
No, they have no frequencies in common. The TLKR-T3 uses the PMR446 frequencies common in Europe. The T5720 uses FRS freqeuncies common in the USA.
Dec 19, 2008 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
500 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
