Magic Sing Along Consumer Microphone Logo
A
Anonymous Posted on Jun 01, 2014
Why my magic sing no power
Pls help me to fix
2 Related Answers
Anonymous
  • Posted on Jun 26, 2009
SOURCE: How to convert Pal to NTSC Magic sing Model 5.91
  • How can I Convert NTSC to PAL mode or vice-versa?
  1. Press the [PWR] button while pressing [8] button for PAL TV mode.
  2. Press the [PWR] button while pressing [9] button for NTSC TV mode.
Anonymous
  • Posted on Nov 19, 2009
SOURCE: Can't power ON...
See if the microphone connector wiggles. It shouldn't move, but if it does, the legs on the connector can snap inside.
Magic Sing ET19KV On connecting Magic Sing through RCA Cable, get buzz sound on my speakers Have chked on diff TV's and replaced the RCA cable.The Video is clear, but getting buzz on speaker
Most buzzes are caused by one of two things: "DIRTY" power or a lifted\non-existent ground. Allow me to explain;
"DIRTY" power is just that. It comes in and carries a lot of static with it. Most newer systems have filters built in on the power side of the main board. The fix? Try running your Magic Sing from a wall socket that doesn't have anything else pulling from that particular circuit. You should also invest in a GOOD power strip and not one that cost $5-$10 bucks. All these are good for is getting power to multiple products simultaneously, AND they don't have the resistors and filters to give you a constant 120v AC.
Monster Cable Co. was a very sought after item up to the point to where Radio Shack no longer carried their products.
If you really want to get your money's worth out of the instruments you buy, don't slack on the power strip. This will be the most costly mistake ANYONE can make.
Here is an article that explains what I did and gives you answers on how to fix this issue.
Hope this helps. Dirty Power What It Is and Why You Need to Clean It Up Schneider Electric...
4helpful
2answers
Not power on the light,and not function the microphone.
if it is a cordless microphone, there may be cell in it. pls find & replace it. if microphone is connected via wires, may be wire is open. try to check the wire with a resistence tester. if found defective, replace the wire.
1helpful
Magic sing service center in mandaluyong or pasig
Hi jun64. Magic sing service center can be contacted and located at the following places you are asking for.
In Mandaluyong:
ASERCO SERVICE CENTER
Unit J Facilities Center (Infront of BPI and BDO Wack-Wack)
#548 Shaw Blvd. Mandaluyong City
(02) 718-0493
(02) 718-0496
(02) 716-0499
And in Pasig:
(Head Office)
#18 Evangelista St. Santolan Pasig City
(02) 682-7679
(02) 647-5375
(02) 681-9739
I hope your magic sing will be fixed soon so you can start singing again! Have a nice day!
2helpful
My magic sing microphone stopped working how do i fix it
my magicsing doesnt switch on, neither with batteries nor with a given power supply
3helpful
I have connected the Magic Sing to a HD TV and a home theatre system and now get a sound-lag between the voice and the sound on the home theatre. Any ideas?
You need to connect directly the sound wire of your magic sing to your home theather while the video wire of your magic sing directly to your hdtv. If its difficult to do because of distance, buy an rca extension to extend your magic sing wire to make it reach to the other end.
3helpful
3helpful
Change from PAL to NTSC
You need to configure it out.
1. Connect the magic sing in your TV
2. Turn on your TV
3. Magic sing should be Off
4. On your magic sing; Press and Hold "8" then while holding "8" press "power button", count for thre seconds then release both buttons (PAL to NTSC)
or
On your magic sing; Press and Hold "9" then while holding "9" press "power button", count for thre seconds then release both buttons (NTSC to PAL)
NO BACKGOUND VOCALS
Hi im joe,
Regarding your concern the ET 3000 magic sing does not have background vocals at all. The manufacturer design the magic sing for sing along purposes only but they are now improving there future products to have that feature with background vocals.
Can't power ON...
Top Magic Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
