Question about Motorola Walkie Talkies 2-Way Radio
I have 4 motorola walkie talkies the channel numbers on one do not match the other three when they are on the same frequency how do i reset the one that is wrong
Randy Reynard
    Master:
  • 623 Answers
If they're not exactly the same model they may have different channel indexes. If the "oddball" is a combination FRS/GMRS or if the other 3 are, they'll have different numbering. As long as you can talk between all of them, just make note of the "right" numbers when they're working.
Posted on Jun 03, 2014
christopher richard
    New Friend:
  • 3 Answers
Check if the programmed frequency of the radio match with the other three radios, may be they are not in the same frequency.
Posted on Jun 02, 2014
Richy GC
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Go through the menus on the radio and change the channel and make sure the sub channel is the same also.
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
Posted on Apr 09, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: i have a sx600r motorla walkie talkie and mess up the frequency
You will need to set the menu options to match one another. Here is a copy of the user manual to assist you. The frequency, interference code eliminator, and the Qt filter must match one another.
http://www.giantintl.com/ContentManage/manuals/Moto/SX600%2012-21-07.pdf You'll find what you need under the heading of menu options on page one, and it continues onto page 2.
Posted on Aug 23, 2009
I cant connect my two walkie talkies, how can i do talk between my two motorola t7150
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T71xx.pdf Programming instructions begin on page 19. Your frequency and code must match identically for the radio to work together.
Best regards.
Jan 13, 2011 | Motorola T7150 (22 Channels) 2-Way Radio
How do i sync two T4500 walkie talkies for use?
Here is a copy of the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
You will need to program the frequency, code and Qt filter (if any) to match one another. For basic operation choose a frequency number and then set your code and Qt filter (if any) to off (zero).
Best regards.
Apr 14, 2010 | Motorola Talkabout T4500 (7 Channels)...
I am trying to pair my motorola walkie talies
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
You will need to program the frequency, code and Qt filter (if any) to match. For basic operation set the frequency and then set the code and Qt filter (if any) to off (zero).
Best regards.
Apr 14, 2010 | Motorola Walkie Talkie 2-Way Radio
Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
Feb 28, 2010 | BellSouth 1061 (14 Channels) 2-Way Radio
I have a t5500 that will no longer transmit or recieve with any of my other motorola walkie talkies. any ideas
Check the settings of the Frequency, Code and Qt filter on your non-functioning radio vs. the working ones. They all should match identically. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Dec 28, 2009 | Motorola Walkie Talkies 2-Way Radio
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Oct 05, 2009 | Motorola Walkie Talkie 2-Way Radio
I have a sx600r motorla walkie talkie and mess up the frequency
Aug 23, 2009 | Motorola Walkie Talkies 2-Way Radio
Apr 09, 2009 | Motorola Walkie Talkies 2-Way Radio
Pick up other walkie talkies
Should do. The available channels are defined by the regulator rather than by the manufacturer. Only thing to watch out for is similar looking devices designed to be sold into different markets (for instance, radios made to the European PMR446 standard work at a slightly lower frequency than those intended for sale in the US). A.
May 31, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola Walkie Talkies 2-Way Radio Logo
205 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
