Question about Krups XL6 Power Combi Food Processor
How do you unlock the lid on the food processor?
Tough to unlock the lid. I don't know how to unlock it and remove the lid
Posted by Dee Rinaldi on
Jerry Kramer
  • 3,904 Answers
The locking happens at the handle. You need to turn the lid counter clockwise to take it off and clockwise to lock it into position.
Posted on Jun 02, 2014
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
The lid for my mini cuisinart hit the tile floor and broke. I need a replacement. I live in Vancouver, British Columbia. Do I buy it on line, or in a store near by. Thank youNora
We don't stay in the same vicinity, so I don't know precisely where you can get the replacement. So I would suggest you order it online.
Click on the below link to order for the replacement.
http://www.kitchenworksinc.com/Cuisinart/Cuisinart-Mini-Prep-Parts.aspx
Please let me know if your need more assistance....
Regards.
Aug 24, 2011 | Cuisinart DLC-1 Mini-Prep Food Processor
GE 14-cup digital food processor; bowl cracked, either by lid fastening or ice cubes in the bowl while chopping mode; don't know exactly. Is this covered by warranty ? Or are separate bowls available...
how old is your processor? did you buy an additional warranty when you purchased it? If so you should read the paperwork. Whats covered,and not, should be listed. you can probably buy a replacement bowl for it on the website.
May 11, 2011 | GE Food Processors
I can't figure out how to use it.. I just want to make a smoothie!
You can get a manual at WWW. euro-pro.com.
In order to use the blender the food processor bowl and lid must be LOCKED in place. Turn the lid on processor until it's locked. Then you are ready to use the blender. Select desired speed or pulse.
In order to use the processor, remove the blender and place the gray lid in its place. It should be locked. The lid keeps the blender shaft from spinning and allows the shaft on the processor to turn.
To remove the processor bowl, gently lift up on the lid to unlock it and then turn it away from processor. Bowl lifts off. That's it! Enjoy!
Hope I have been of some help to you.
Feb 10, 2011 | Bravetti Platinum Pro Quad-Blade Food...
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Lid stuck on bowl of my Cuisinart Mini Prep Plus.
Generally they twist off, but on the DLC-2, if the lid won't come off, a replacement bowl and lid is around $18.00
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Cuisinat DLC 8 Plus Bowl won't unlock
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Often it is difficult to unlock the bowl on the cuisinart food processor
Have you tried removing the lid first? Mine has an interlock where I have to remote the lid before I can unlock the bowl from the machine. Good luck!
Sep 20, 2008 | Cuisinart DLC-5 Food Processor
How do i remove the blade of of the bowl?
Remove bowl lid first
Then twist bowl to left (as you face front of machine)
Lift bowl up - blades will come with it
Feb 11, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
DLC 7 pro
Removing a Cuisinart Food Processor Work Bowl
-Tha Mp3 Doctor
Oct 18, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Krups XL6 Power Combi Food Processor Logo
654 people viewed this question
Top Krups Food Processors Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Krups Food Processor Expert? Answer questions, earn points and help others
