Question about Google Android Tablets & eReaders
Locked out of maylong m-270 tablet
Forgot pattern lock
5 Related Answers
mcwtocom
mcwtocom
SOURCE: I have locked my MID Android Tablet. I have
pls try reset your mid tablet pc, if it can't, maybe you can contact your seller. if you can't contact your seller, you can ask another mid tablet pc seller online help sevier. as: http://www.mcwto.com, they are an mid tablet pc wholesaler.
Posted on Jun 14, 2012
Nate
  • 133 Answers
SOURCE: How Do I Get Past a Pattern Lock MID8024
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Posted on Sep 26, 2012
Anthoney
  • 12 Answers
SOURCE: How can I download google play to a maylong tablet?
touch the browser app and go to google.com and is search bar type google play
Posted on Apr 18, 2013
Tammy Alcorn
  • 43 Answers
SOURCE: My sons tablet is locked with a pattern lock with
Turn off the tablet for a little bit and then turn it on and should be back to normal.
Posted on Aug 04, 2013
Emery Miller
  • 26 Answers
SOURCE: Model:v705-s tablet pattern lock.so unlock the
If you cannot unlock the tablet, look up the way to do a hard reset. You will lose all data, but it's one of your only options.
Usually the following method works:
1. Turn the tablet off.
2. Hold the volume down button.
3. Hold the power button.
This should boot you into your devices restore/update screen. If that combination does not work, volume up + power should.
4. Navigate to the wipe data/factory reset.
5. Wait for it to reload, and you're done.
Posted on Nov 21, 2013
Unlock tablet forgot pattern
Take a look at these two links that each offer some methods you can try. I hope it helps.
How to unlock android tablet after forgetting pattern lock
How To Unlock My Tablet if Forgot the Unlock Pattern
I post on behalf of HP.
Jul 10, 2015 | Tablets & eReaders
I forgot my tablet pattern what do I do
I forgot my Fondi wifi android 4.4 pattern lock
There should be an option for forgot pattern or something to that effect. Other than that you will have to completely restore the tablet
Dec 09, 2014 | Tablets & eReaders
Change pin number
hard reset by recovey options
Nov 14, 2014 | Tablets & eReaders
Forgot pattern to unlock excelvan q88 android tablet
my son entered incorrect pattern on Vipad Q 88, now its locked, gmail account is not accessing. Is there any solution for that?
Jan 06, 2014 | Excelvan Tablets & eReaders
Forgot password pattern for my a13 tablet
how to reset this thing when itz pattern locked ........?
Jan 05, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Forgot lock pattern on lock screen on a 7" uniden tablet
I have a uniden tablet and have had it for about 6 years now I forgot the password and I can't get into it. I have tried everything can someone help? ??????????
Dec 29, 2012 | Uniden Tablets & eReaders
Forgot pattern lock android china tablet
ihave a china android tab and it is now pattern locked
Dec 27, 2012 | Tablets & eReaders
Tablets & eReaders Logo
37 people viewed this question
Top Google Android Tablets & eReaders Experts
ray gallant
Dayton Computer
Dayton Computer
Dream
Are you a Google Android Tablet and eReader Expert? Answer questions, earn points and help others
