Question about Kodak EasyShare C340 Digital Camera
How do i turn off the date and time on the Kodak easyshare c340?
We set the time and date a long time ago and now want to turn it off
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Kodak Z700 not firing up
Guest is right. Clean the contacts, bend the contacts with a small flat head screw driver upwards "GENTLY". This should work. Might have to repeat every couple of months. Forget regular batteries. Use the rechargeable ones. MUST be fully recharged.
Posted on Sep 24, 2008
Anonymous
SOURCE: Kodak z1275 easy share camera
never use kodak again!!!
Posted on Dec 17, 2008
Anonymous
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
Posted on Jun 02, 2009
Anonymous
  • 262 Answers
SOURCE: My wife`s Kodak Easyshare V1253 has to be reset
Regarding the date and time, Actually its normal everytime you removed the battery you need to reset the date its is because the camera doesnt have a internal or built-in battery that can run the internal clock or maintain the date settings.,
Regarding the taking picture that will take time, it is because your using a too high mega pixel of the camera, Higher mega pixel will have a bigger file size and it will take to process the picture. the best thing you can do is to lower the Mega pixel or the picture size make it atleast 5MP or 6MP., I can guarantee to you you will have a great picture outcome and lessen the time of processing picture.
By the way you can lower the mega pixel (picture size)by pressing the menu button of your camera
Posted on Nov 12, 2009
Anonymous
  • 1234 Answers
SOURCE: I have a Kodak Easyshare M1033. When my camera
HELLO SIR
turn it on , Press Reset Buttonù
turn it off , still pressing The switch on button 10 seconds
It works for me
Posted on Aug 29, 2010
I cannot reset time and date on my samsung z2
Want to set the date and time for your mobile phone? Follow these easy instructions.
From a Home screen, tap the Arrow icon to display all apps.
  1. Navigate: Settings > Date & time.
  2. To use network-provided values, turn on the following:
    • Automatic date & time
    • Automatic time zone
  3. When manually setting data & time, perform the following:
    Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
    1. Tap Set date.
    2. Adjust the date then tap OK.
    3. Tap Set time.
    4. Adjust the time then tap OK.
    5. Tap Select time zone then select a time zone.
  4. If desired, tap Use 24-hour format to turn on or off .
May 23, 2018 | Samsung Cameras
Why when i try to login my facebook on my laptop saying site not trusted but can access it on the phone
Yes, Agree with the comment above about the date and time. My computer continually did that for every site. the date was set right month and day but was set at 2011. as soon as i put in right date and year everything was fine.
Dec 04, 2014 | Facebook Social Network
Every time I power on my laptop, the date and time is set to years ago. I've changed it to the correct date and time a lot, turn it off when I'm done, but it goes back once I turn it back on. I have a...
You need to change the internal clock battery. It's referred as a CMOS battery or a system battery. It will most likely be a silver button cell...either a 2016 or 2032. You will most likely find it by removing the main battery and one of the bottom access covers. After you change it, boot up to Windows and change the time and date. It should now retain the settings.
Nov 05, 2013 | Gateway Computers & Internet
The date will not stay set on my Casio SE S300
Dear dovscorner
You may have to change your battery to be able to save the date.
Best Regards
Mazagange
Apr 10, 2013 | Computers & Internet
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
Every time i turn my laptop on the time and date keep changing and going back nearly 3 years,i have been told it is the CMOS battery is this right?
What you have been told is correct. When the real time clock battery (CMOS) runs out then the date and time will revert back to the day the bios was programed, in your case 3 years ago.
You can set the date and time while you are using Windows but each time you power the laptop down it will loose this information.
A quick workaround is not to power the laptop off but put it to sleep instead until you have got a CMOS battery for the laptop.
Regards.
Aug 15, 2010 | Computers & Internet
Hello, When I just bought this camera several years ago, I entered the time and date settings and after I've done this it never asked for time/date settings again. But now every time I turn on the...
you may need to take it in to the camera place to get the internal batery for the clock replaced also you may need to up load the driver program for the camera
Aug 15, 2010 | Canon PowerShot A520 Digital Camera
How do i turn off the date on my kodak m863 camera. I turned it on a long time ago and it won't give me an option to turn off the date and time. HELP!?
HI there press the menu , then scroll down for setting option . From setting you can find the date & time on/off option. Select from there as per your choice & use that. Thanks & waiting for your feedback.
Apr 01, 2010 | Kodak EasyShare M863 Digital Camera
I just sent an email and it is now 10:20 pm but the time on the outgoing email that I just sent 8 minutes ago says 3:12 am and the date says 12/17/09 when it is still 12/16/09. My boss is going to see the...
No worry susan! your mail date/time settings and system settings are different, so change these settings in your mail at an early by selecting timezone! have fine!
Dec 17, 2009 | Yahoo Mail
Won't set date and time
Greetings bpm123,
My suggestion is to simply turn the date time stamp off in the setup menu. In reviewing the instruction manual, it appears you can obtain instructions on how to do this starting on page 21.
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 24, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Kodak EasyShare C340 Digital Camera Logo
80 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
