Question about Samson C01U Consumer Microphone
Samson C01 U disconnects automatically after some time while I am recording my voice
Hi, Samson C01u disconnects automatically after some time and i have to re-plug it in the usb port to restart it. I am using windows 7 home edition and my speakers are attached via an audio interface.
  • Anonymous Apr 27, 2018
    What software are you recording in?
4 Related Answers
Anonymous
SOURCE: tips on Using the Samson C01U with Cakewalk Pro Audio 9
Try this:
Control Panel > Sound Audio Device > go to Voice Tab > check your drop down list for Voice Recording and make sure you put on Samson C01U then test your hardware and see you get any pick up. I had to research on what to do.
Now my problem is why the mic is only picking up on the left side of the ear instead of the right. =/
Posted on Jan 08, 2009
PBandJ
PBandJ
  • 29 Answers
SOURCE: C01u PROBLEM PLS HELP ?!
That's the way it's supposed to work. It's a mono microphone, so there's only one signal to record.
Set up your recording software so that it only records the Left channel. It describes how to do this on the Samson FAQ page and in the Owner's Manual:
"In your digital audio workstation (DAW), create a mono audio track, and set it to the Left channel of the C01U (the Right channel should be ignored). Arm the track for recording, and adjust the input gain by using the software control in your computer's operating system"
Don't try to alter the pan so both sides are the same; that will just screw up the levels and noise.
Posted on Mar 01, 2009
Fred Yearian
  • 5603 Answers
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
Andrew Conroy
  • 298 Answers
SOURCE: hi i have a problem
Some users have reported problems with this microphone not working properly with Windows Vista operating system but it is fine with XP and Windows 7. Some MAC & Linux users have also encountered installation problems.
All condenser microphones require a power source to make them work. In the case of USB mics they take their operating power from the computers USB port. If you have a lot of other USB devices connected then there may not be enough power available to run them all at the same time. Disconnect any devices that you do not need.
First step would be to make sure that you connect to a main USB port (not a separate hub). If you are using a desktop or tower computer use the USB ports on the rear of the computer, which are mounted directly on the motherboard. Front panel USB ports are normally on a hub and may therefore prove unreliable with some devices..
Next try to diagnose the problem by process of systematic elimination
  1. Test your sound-card - does it work okay with other sound sources such as a microphone plugged into the normal microphone input (red socket) on the sound-card or on your front panel.
  2. Do you have another USB sound source that you can plug in to make sure that your computer will accept sound from that route?
  3. Now check the microphone for faults. Is the LED on the microphone coming on to indicate it is getting power?
  4. If no the microphone itself, or the cable, may be faulty. Try plugging it in to a different computer, games console, stereo or audio device with a USB input to see if it will work there (note not all audio devices will have sufficient power on the USB socket so this test may not be conclusive)
  5. Is the computer operating system actually recognising the presence of the microphone in the first place?
  6. Does a little balloon pop up to say a device has been plugged in - and does it correctly identify what that device is by telling you it's name?
  7. If the system recognises the device but doesn't correctly identify then you may need to install a driver for the microphone.
  8. From the windows start menu go to CONTROL PANEL.
  9. Click on SYSTEM, then HARDWARE, followed by DEVICE MANAGER
  10. Scroll down to SOUND VIDEO & GAME CONTROLLERS. Does the microphone appear here? If yes does it have a little yellow asterisk next to it? If so it is a driver issue.
  11. Sometimes a USB driver issue can be resolved by uninstalling the USB controllers and reinstalling them. Scroll down the list of devices in DEVICE MANAGER until you get to UNIVERSAL SERIAL BUS CONTROLLERS. Systematically uninstall every device listed here. To do this RIGHT CLICK on each device and then click UNINSTALL. Then on the TOOL BAR click CHECK FOR SYSTEM CHANGES. this will reinstall all USB devices and controllers.
  12. If that does not solve the USB problem go to your computer manufacturers website and download the latest USB drivers for your machine.
  13. Assuming you have overcome the USB issue (or if this was not the problem anyway) you now need to check that the microphone is selected as your default audio device.
  14. To do this go back to CONTROL PANEL, followed by SOUND & AUDIO DEVICES
  15. Click on AUDIO and, under the SOUND RECORDING tab select your microphone from the drop down list.
  16. Then click the VOLUME button which will open a window called RECORDING CONTROL
  17. Make sure there is a tick (check mark) against microphone and that the slider is up at the top of the scale.
  18. If everything is okay up to this point the problem may well lie in the settings for the audio / recording program that you are using. Most programs have some sort of wizard for testing audio settings, which you will need to work through.
Posted on Jan 30, 2011
I have a samson c01u and using audacity. i set the input level in the control panel to 100 and also in audacity, but the the volume is still too low. i can barely hear my voice. what do i do?
1. Did you select Left channel only in Audacity for the track you're recording?
2. Maybe it's a defective mic. Try it on another computer/software/USB cable/USB port and if it still doesn't work get Samson to replace it.
Apr 05, 2014 | Samson C01U Consumer Microphone
My samson microphone c01u works but i cant hear my mic thru my speakers it does not record out
That's normal. You're supposed to record a track and then play it back. In order to hear it live you would need to enable "software playthrough" in your recording software, but there will be a delay, so it probably won't be much use.
Aug 27, 2011 | Samson Audio C01upak C01u Microphone and...
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
I got a 35 mm cable on my c01 and it won't work on my pc does someone know the problem..cuz when i put another mic in it just works fine
You Samson microphone requires phantom power to operate. PC's don't have phantom power. You need to run your mic thru a mixer that has phantom power.
Apr 14, 2010 | Samson C01U Consumer Microphone
Whistling background noise with Samson C01U USB condenser mic
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
After i record my voice with the microphone, it comes out 1 side
The Samson C01U records in mono, not stereo. This is why you hear sound coming only out of one (the left) channel.
Mar 29, 2009 | Samson C01U Consumer Microphone
Jan 08, 2009 | Samson C01U - USB Studio Condenser...
Samson C01U Consumer Microphone Logo
55 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
