Question about HTC G1
Put 10pounds on playstore but only coming u r49p
Put 10 pounds off a play store card on a play store but only 49 pence has gone on ly!49p in sbiwing
How do I re install google play on my android
If you mean the Google Play Store, you can download the .apk file from sources such as
http://earth.androidapksfree.com/venus/com.android.vending-v5.4.12-80341200-Android-2.3.apk
(find links for the latest version at http://www.androidapksfree.com/apk/google-play-store-apk-latest-version-download/ )... then transfer it to your device using a USB cable connected to your computer (put it in the Downloads folder).
In your device's Settings, go to Security, then put a check next to 'Unknown Sources' which allows apps to install from a local .apk file. Next, use the MyFiles app to go to Recent files. Find the com.android.vending-[version].apk file, click on it, then follow the prompts to allow it to install.
Once it's finished installing, go back to Settings->Security and UNcheck the Unknown sources option again (you don't need that checked to install apps from the Play Store).
Apr 07, 2015 | Android Apps
My google play store has stopped how can i put it back on
What's the error? Just go to settings, apps, search for PlayStore and tap clear cage and clear data. Do the same thing with Google Play Services. Open the PlayStore app and follow the instructions.
Feb 05, 2015 | Tablets & eReaders
Download google playstore for kendal fire 7
Go to google and google, google playstore for kindle fire and the download ,ink will come up
Jan 06, 2015 | Google Cell Phones
How do i take my credit card off my hp tablet
Make sure you look in your play store settings.
You could either remove your card or have the playstore to require your password to install paid apps.
Jun 20, 2014 | HP Slate 10 HD 3600 3610ea 16GB Tablet -...
Had playstore app and it disappeared how do i gate it back and report
Lisa I am having the same problem. I went to go on my Google play store and a message popped up saying app is not installed on this device. Now I don't know how to put it on there.
Jun 18, 2014 | Android Apps
What do I do if my playstore is not working on my phone?
You mean App Store? Maybe because your password has been modified or the phone got reset on passwords and you need to log in again. Try that first. Otherwise you need check settings on App Store. Good luck.
May 16, 2014 | Samsung Galaxy GT-S5570
Playstore will not open
In this situation, your best bet is to go into your options, enable apps from an outside source, and then navigate to here: http://www.androidpolice.com/2013/10/21/download-latest-google-play-store-4-4-21-with-slide-out-navigation/ OR just do a quick google search for Google Play store apk. Install it form here to replace your current one.
This happens when your updates to the play store get interupted or sometimes they just corrupt for no good reason.
Nov 19, 2013 | Samsung Galaxy Rush Boost Mobile
What is the maximum weight capacity for the VPT-240SE?
I don't have the manufacturers specifications, but stay under 4 pounds and you should be ok. more that 4 pounds and you may have problems with vibrations. More than 10pounds and you may break the head, or tip over the tripod.
Mar 23, 2010 | Photography
HTC G1 Logo
81 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
