Question about Frigidaire FEF336BC Electric Kitchen Range
How to fix f13 error code on a tappan stove - Frigidaire FEF336BC Electric Kitchen Range
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that you are receiving an F13 error code on your Tappan range. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I ask that you please leave your model number in the comments as well. Hope this is helpful.
-Best Regards-
WP
Posted on Jun 02, 2014
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
How to fix the F13 error in this stove
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 15, 2010 | Frigidaire FEF336BC Electric Kitchen Range
My stove is blinking F-1 and beeping. It has been
Hi jwwilliams8,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Nov 19, 2009 | Tappan TGF320 Gas Kitchen Range
Getting F13 err code when trying to bake or broil. Frigidare model PLES399EC
Hi william_j522,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Oct 22, 2009 | Frigidaire PLES399EC Electric Kitchen...
What is a f13 error code on a Frigidaire Gallery smooth top stove
Hi danair2,
Regards
R.K.
Aug 14, 2009 | Kitchen Ranges
Tappan stove
f-1 error code is the control failure error.replace the electronic control board.hope this helps thanks and Godbless
Nov 02, 2008 | Tappan TGF363 Gas Kitchen Range
Model FGFL87DSG error code F13
hi there,
here is what you can do:
disconnect power to the stove completely and flip the corresponding breaker on and off on the breaker box.
let me know if this helps.
Oct 12, 2008 | Frigidaire Kitchen Ranges
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
733 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
